Old 04-24-2023, 03:19 PM   #1
Rich osmond
Default Re: Tire Help for Heads-up Manual Transmission Class
Thanks. Aluminum flywheel, single clutch disc 10” min, but we can run a tamer. First gear ~ 3:1, second gear ~2:1. Appreciate the help.
Rich osmond is offline   Reply With Quote
Old 04-24-2023, 05:34 PM   #2
Jim Caughlin
Liked 806 Times in 246 Posts
Oh boy, here we go again...
Jim Caughlin is offline   Reply With Quote
Old 04-24-2023, 05:38 PM   #3
Rich osmond
OK. I’m just seeking a little help. Thx
Old 04-24-2023, 10:06 PM   #4
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
why wouldn't you put a 30x9 bias tire the Stick stocker guys run? i know thats why you are asking what to use, but I would think a 30x9 would give a much better contact patch over a 26x10.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 04-24-2023, 10:17 PM   #5
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
28s are the biggest they can run
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-25-2023, 01:20 PM   #6
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
I used to run the 28x10.5 Stiff in Renegade. Back then we had to weigh 3000 and made more HP 850 but with a single disk Ram and a adjustable pressure plate I 60 footed 1.25 and ran 9.0’s a DOHC 4.6
I know this isn’t your combo but it’s about as close as you’re going to get here!
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 04-25-2023, 01:37 PM   #7
Rich osmond
Thank you, James. This is very helpful and something I will consider. As you know, I will need to balance clutch slip, wheel speed, and rotating weight, so I will probably need to test with a short tire/gear package, vs a tall one. Thanks again.
