Liked 53 Times in 38 Posts
All good ideas but I was thinking of how track personnel would turn it off in an emergency, in back it’s easy but not wanting to run big cables to front. I’ve been thing about the solenoid thing too but didn’t want it egauged while in use.
Liked 125 Times in 59 Posts
Not a class car but I am using a high amp relay and E-stop buttons on my steering wheel and on the back of my car.
![]() ![]() Rear button ![]() Relay ![]() |
Liked 80 Times in 44 Posts
Just use a on-off switch with a negative or positive wire hooked to the solenoid. It can be a 14 gauge wire, The wire connects to the small studs on the solenoid. Hope this helps.
I wouldn't cut the negative side. If you have a wreck and the wire gets cut and goes to ground the relay won't shut off.
Liked 875 Times in 236 Posts
Absolutely !. Rule book also specifies interrupting the positive side only.
