Old 02-20-2023, 05:54 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Re: manual trans and clutch quaetion
Adger, I have already talked with Kevin and the LS engine is OK. He tells me any door car or pick up that is 1979 or older is OK. I like your roadster idea.
Woodfin is online now   Reply With Quote
Old 02-20-2023, 05:57 PM   #2
Woodfin
Adger, Kevin explained to me that they relaxed the engine requirements in an effort to make it more reasonable to build a car. They are allowing the index to be the governor.
Old 02-20-2023, 06:04 PM   #3
Woodfin
Adger, we did not specifically talk about this, but I expect, since it is basically a no electronics class, the LS or any engine will need to be carb or mechanical injection with distributor or mag.
Old 02-20-2023, 08:21 PM   #4
e vassar
Liked 271 Times in 107 Posts
I don't know the rules for the classes, but I'll make a assumption no electronics would be delay boxes,throttle stops etc. Not engine mgnt systems.
Old 02-20-2023, 08:59 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Larry the way the class is structured I think your assumption about FI and Electronic ignition would be correct. It would not be in the spirits of the old Modified production. I've got an old Accel BEI ignition and cable drive tach I'm going to use.
Larry, I've even got an old set of Lee Shepherd Iron V-6 heads. I might show up with a V-6.
Adger Smith (Former SS)
