#1 | |
Liked 346 Times in 150 Posts
Phil Molski PMR Performance S/C 1623 |
Liked 256 Times in 100 Posts
I now have several years of experience with 16-volt systems. I do not see any advantage to the 16-volt battery, and I have returned to a 12 volt with alternator. I now think that overall, the 12 volt has the most advantages.
Liked 172 Times in 53 Posts
I put one in my stocker last year. Fuel pump works better, with the fan and water pump running I can cool my car in about half the time that I used to, maybe less than that.
Liked 239 Times in 114 Posts
It is nice how fast those 16V batteries charge !
Liked 37 Times in 33 Posts
I personally prefer the 16V. I also agree with SS3011 on how fast the 16V charge.
Liked 586 Times in 162 Posts
I use a 12v with an East Coast mini alternator, it's an Optima red top battery. Weighs 46 lbs had it for 7 years and counting with zero issues. Cooling? I run a large aluminum radiator and big fan and CSR water pump and never have to let the fan run when back in the pits or after a run. I also use an Anti Gravity lithium which weighs 3 1/2 lbs when I want to get some weight off the nose. I can adjust the valves with the little one and spin it over to fog it or start over and over. It charges in minutes. No issues with either battery.
Liked 2,336 Times in 464 Posts
When I run A/SA with my car I have to take a lot of weight out of the rear. I use the light weight 16 volt 9 lb battery's BP
