Old 10-07-2022, 12:22 PM   #1
weedburner
Liked 20 Times in 16 Posts
Default Re: Clutch guys
I think the typical static+CW "slipper clutch" tune leaves a lot on the table.
The basic clutch tuning challenge for most in drag racing applications is that the ideal amount of clutch clamp pressure during launch is less than what's ideal after the shifts. The traditional adjustable static+CW clutch attempts to solve that problem consistently by using centrifugal weights in a way that makes clutch clamp pressure increase with engine rpm. Lowering launch rpm well below the shift rpm has the effect of relaxing the amount of centrifugal clamp applied, which can in-turn prevent the clutch from pulling the engine down below its torque peak during launch. Then by the time the engine reaches the shift point, clamp pressure has increased to the point where the clutch slips much less after the shifts. More slip during launch, less slip after the shifts. Problem solved?
The adjustable static+CW clutch solution sounds great until you consider this- "driving into" an adjustable clutch at an averaged 6200rpm will produce 52 power pulses during that critical first second after dumping the clutch. But spinning at an averaged 8000rpm the engine will produce 67 power pulses over that same time period. That's a gain of 28% more power pulses during that critical first second after dumping the clutch due to higher launch rpm. Even if the engine makes more torque at an averaged 6200 vs 8000, it won't make 28% more torque at the lower rpm to make up the difference. Higher average rpm during launch definitely has the advantage as far as power production goes. Problem with the traditional "adjustable clutch" solution is that when you raise launch rpm you also increase clutch clamp pressure, which limits how far you can go without upsetting the chassis. I suspect that's a basic reason why James chooses to set his SS/AH car off at 6200 instead of 9500.
There's also a difference in the amount of inertia energy stored within the engine's rotating assy. More energy stored prior to the start of the clock means more energy is available to move the car after the clock starts running.
The key to exploiting launch rpm is finding a way to harness more launch energy without upsetting the chassis/tires with a harder hitting clutch. An alternative to the traditional static+CW method of clutch tuning is to vary clutch clamp pressure in a way that is not dependent on rpm, but rather by controlling clutch clamp pressure externally during launch via throw-out bearing position. This makes it possible to have two separate stages of clutch engagement that are independent of engine rpm- a 1st stage level of reduced clamp pressure that is optimized to take advantage of higher rpm launches, which then transitions to a 2nd stage level of full clamp pressure that's been optimized for harnessing energy release after the shifts. In the end, less energy gets wasted due to excessive wheelspeed spikes.
The clutch also gets easier to tune when you abandon centrifugal weights and then crank-in just enough spring to hold after the shift into high gear. From there use a 2-stage clutch hit controller to control throw-out bearing position during launch. Completely eliminates the centrifugal vs base balancing act, as it allows you to adjust launch clamp pressure without affecting high gear clamp pressure. Far simpler way to tune a clutch, and you won't need help from an expert to dial it in.
...If it slips too much or not enough during launch (1st stage), you dial that in with the clutch hit controller from the driver's seat.
...If it slips too much or not enough after going into high gear (2nd stage), you know you need to adjust clutch spring pressure.
There's also a consistency advantage in a dead hook launch vs trying to control wheelspeed.
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 10-07-2022, 02:04 PM   #2
joespanova
Liked 13 Times in 11 Posts
I'm not sure I'm getting what I expected out of the initial question.......clutch management wasn't the consideration here. Specifically , you could make the clutch work at a variety of RPMs......my consideration was the connection between "that" and making it work around / at / near , the aforementioned hypothetical engine torque / power point. In other words is the effort (through clutch tuning) made to "exploit" the engines peak points of either or just manage it to get the car to work with little regard to either.
Using my own as an example , with no change in the bell housing and enough base ( because I don't use a data logger ) to launch the car well enough to keep me near or well into decent 60 fts. I can apparently spin or wheel stand just by varying launch RPM. And a wheel stand could be very high , or very little with spin. So the initial thoughts are outside of the bellhousing ....leaning towards , am I changing the cars characteristics at launch because of how the engines power band comes into play ( way over peak torque ) or right at peak torque. It is likely the clutch CW has some input here.....BUT which has the greater influence?
Old 10-07-2022, 02:35 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
Back years ago when I ran a stick in my car. The car was faster launching at high RPM. this was before all of the good clutch stuff and rev limiters we have now. I would leave at 9000 RPM and pull the shifter to second as quickly as possible. Then shift the remaining gears at 8000. The car liked a light flywheel 13 lb. Clutch was 1800 base as I remember with a six pad disc. Dead hook. I had 2 transmissions one 305 low and one with a 3.19 low. SS/I and SS/J. It was brutal on parts.
Mike Pearson 2485 SS
Old 10-07-2022, 03:52 PM   #4
weedburner
Because you have centrifugal adding clamp pressure with rpm, the higher you launch the harder the clutch hits.
When you are launching way over the engine's peak torque, the clutch hits harder and your engine is likely initially losing rpm during launch. That loss of engine rpm adds torque to the transmission's input shaft. That extra torque due to stored energy exiting the engine's rotating assy, along with a harder hitting clutch, causes excessive wheelspin before the car gets a chance to transfer weight.
When you are launching from a lower rpm closer to your engine's torque peak, the clutch slips more and the engine may or may not lose rpm. If it doesn't lose rpm, the input shaft will only see engine torque during launch. If you launch below the engine's torque peak, the engine will gain rpm during launch. In that case the engine's rotating assy will absorb some of the engine's torque, which will in-turn reduce the torque that the input shaft sees.
Note on the graph below that this 425ftlb engine puts out way more than 425ftlbs when it is losing rpm, and much less than 425ftlbs when it is gaining rpm. That's due to the engine's rotating assy releasing and absorbing energy as it loses or gains rpm...
Here's those calculated input shaft torque numbers multiplied by the transmission ratios to show driveshaft torque...
If you are wondering how accurate those calculated torque numbers might be, here's those calculated driveshaft torque numbers compared to the actual AccelG trace from that pass...
Grant
Old 10-07-2022, 04:16 PM   #5
weedburner
Grant
Old 10-07-2022, 09:03 PM   #6
joespanova
Weedburner , that's good stuff and my take away ( and what I'd been realizing lately ) is that I've been launching with too much RPM. I'd just figured I needed that engine speed but now realize I've missed the target all along....which will have me drop from , say 7000 or so to 6000 or so...this is a 393 SBC ( n/a ).
Old 10-08-2022, 03:37 PM   #7
weedburner
If you are looking for your best ET, more launch rpm is better as you will have more stored energy available to get the car moving. Problem is the traditional model of adjustable static+CW clutch tuning won't get you there,
Don't confuse more launch rpm with a heavier flywheel as they are not the same with regards to storing energy prior to the start. While a heavier flywheel/clutch will also make more stored energy available for launch, the problem with a heavier flywheel is that the energy you draw from it during launch then has to be paid back before you cross the stripe. The car can launch harder with more stored energy available, but it will then accelerate slower as the rpm's climb back up. Gain some here, lose some there, it basically balances out when the outflow of stored energy is efficient. The problem you see with a heavier flywheel is that it increases the percentage of stored energy that is lost when the tires spin. That is the basic reason drag racers see benefits when switching to lighter clutch/flywheels, an overall reduction of stored energy means less stored energy ends up wasted during wheelspeed spikes after the shifts.
It might help to think of the engine's rotating assy as a torque storage device similar to a battery. You lose engine torque output as you charge it up with rpm, then gain engine torque output as you draw rpm out of it. When you cross the stripe, the engine's rotating assy will be fully charged with rpm. Sure there will be give and take as the engine loses and regains rpm as the car works its way thru the gears, but those gains and losses basically cancel each other out. The thing to look at is the net difference between engine rpm on the starting line vs engine rpm crossing the finish line.
...If the rpm on the starting line is the same as crossing the finish line, then all the engine's torque production made it to the transmission's input shaft to accelerate the car. Start with a full battery, end with a full battery.
...If the rpm on the starting line is lower vs crossing the finish line, that's like starting out with less than a fully charged battery. Some of the engine's overall net torque production gets absorbed charging its rotating assy, reducing the overall net torque available to accelerate the car between the start/finish lines.
...If the rpm on the starting line is higher vs crossing the finish line, then that extra start rpm becomes energy available for launch that doesn't have to be paid back before crossing the stripe. You end up with more torque available to accelerate the car between the start and finish lines than the engine actually produced.
The key to taking advantage of high rpm starts is the ability to control the stored energy discharge rate, which is in-turn controlled by how fast the clutch pulls the engine down against WOT. For that you need a 2-stage clutch. A 1st stage that maximizes efficiency during high rpm launch, then a 2nd stage rate that maximizes efficiency after the shifts.
Grant
Old 10-09-2022, 08:22 AM   #8
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
Hemi cars cross the stripe at over 9500 so you want us to launch there! Lmao no clue
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 10-09-2022, 09:26 AM   #9
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
There is another case where the car is geared for the best 60' time and et which has it on the rev limiter before the finish line.
Stan
