Old 09-22-2022, 07:36 PM   #1
OkieRocket
OkieRocket's Avatar
Liked 6 Times in 5 Posts
Default Re: Wheelie Bar Kit Choices/recommendations
Thanks for the responses and referral to Ken Keir Race Cars.
Also.....CMcAllister, Special Thanks for the very detailed reply...some stuff I hadn't even considered....like being able to "fit" the Car with Bars into the Trailer...
FYI, The Bars may not be a necessity at this point??..I'm trying to head off possible future troubles, just in case. As I've moved the Engine rearward ~ 5" in the chassis, I'm thinking they may be a good idea.
Also, I'm thinking 4130 tubes (maybe 1" OD x 0.095" wall - or whatever is recommended) with Rod Ends at all 4 points. Maybe 60" long - equipped with Springs.
I also do a lot of 4130 TIG Welding, so "assembly/fabricating" shouldn't be an issue for me. As far as a Budget...I'm hoping $ 500 or less for the Kit, or components.
Attached is a Photo of the Rear of the Car to give you a better idea of what I have for a set up.
Thanks again.
Harold
Name:	rearend (Small).jpg
OkieRocket is offline   Reply With Quote
