Old 08-19-2022, 10:47 AM   #1
larrylomascolo
Liked 66 Times in 29 Posts
Default Moroso 7.10×15 front tires
What is air pressure for this tire.no info on tire.for a G.M Abody sml.blk
Old 08-19-2022, 11:30 AM   #2
JeremyDuncan
Liked 354 Times in 79 Posts
Default Re: Moroso 7.10×15 front tires
30psi is good place to start
JeremyDuncan is online now   Reply With Quote
Old 08-20-2022, 02:06 AM   #3
GTX JOHN
Liked 2,483 Times in 697 Posts
We ran 35 PSI
John Irving
741 Stock
741 Super Stock
Old 08-20-2022, 09:58 AM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
Why would you not run these up to 38-40PSI? It's all about rolling resistance.
Jim Caughlin is online now   Reply With Quote
Old 08-20-2022, 11:03 AM   #5
richie 2
Liked 205 Times in 93 Posts
ive seen #50
Old 08-20-2022, 12:33 PM   #6
Frank Castros
Liked 2,719 Times in 959 Posts
We ran 50 lbs.
Old 08-20-2022, 04:47 PM   #7
GTX JOHN
I have never seen any difference between 35 PSI and much
higher pressures in performance.
I used to run more (45 to 50) til 30 years ago when I hit a
collector in the lights = The darn tire exploded and I would
not like to duplicate the ride after that ever again!! Would less
pressure have made a difference - I do not know!
That being said: I think the Moroso front tires are more durable
than the other brands but maybe a bit heavier.
John Irving
741 Stock
741 Super Stock
Old 08-21-2022, 06:53 AM   #8
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Thumbs up Re: Moroso 7.10×15 front tires
I run these tires on the dakota and use 40lbs. They live even from a 10 foot drop, I can attest. Very strong tire, sanhuffs, 40lb's in these tires seems to be pretty good to keep the crossmember, and oil pan love scrapes down to a minumum. They also seem to be made of really good rubber, and don't suffer the cracking issue I have seen with others(Thats not going to work with a wheelstander!)
Eric
Eric Merryfield 1883 STK
Old 08-21-2022, 09:14 AM   #9
Rory McNeil
Liked 1,103 Times in 301 Posts
Eric
I really like the old style Moroso "Drag Special" front tires, not only to they see to hold air better than any other frontrunner type tire I have ever used, they also don`t seem to ever wear out. I had the same set of Moroso 7.10s on the front of my bracket car "forever", (or at least since Mark Faul was driving Tom Turners Dr. Injector Camaro Stocker, which is before Mark got his burgandy Chevelle and Pontiac S/S car, as I bought the tires from Tom back then), and I changed them just a few years ago, simply because I wanted to try a shorter tire. They still looked like new, and would still maintain air pressure over the winter. The only downside to the Moroso is they only come in 3 diameters. I typically ran mine between 30 and 45 psi.
NHRA 6390 STK
M/S 85 Mustang
Old 08-21-2022, 02:16 PM   #10
Frank Castros
It's great to realize a product that's been around for at least fifty years is as good or better now then it was then. God bless the late Dick Moroso, he was a genius.
