Old 04-17-2008, 07:45 PM   #1
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Re: Radial tire chatter
Originally Posted by Todd Geisler View Post
Most of the time I see cars with tire chatter with radials, it's due to either too low of air pressure, or the shocks out back are set too soft.
My car likes the back end very stiff, both rebound and compression.
Todd, the backend is already stiff with 250 lb springs but I do have the shocks set soft. Like I said, I started at 15lbs, dropped to 14 1/2 in the cool weather and was doing great. 1:452, 1:453, 1:452 60 fts. 2 weeks later it got hot and first I lowered the pressure to 14 then I raised it to 16. The last pass I eased it out trying to win the race and broke out by .005 so I didn't really get to try the highr pressure.
Thanks for the response.
Floyd Staggs 787 SST
Old 04-17-2008, 09:56 PM   #2
Todd Geisler
Liked 345 Times in 149 Posts
That's the same size tire I run. I've run the BFG's, M/T's, now the Hoosiers. All have worked with 18 psi cold, as high as 19.5 psi hot. Typical usable range for me is 16 to 18 psi. I can't remember ever going to 15 psi.
I run 120 #/in rate coil springs out back (stock type coils) and double adjustable shocks. You need the firmness to come from the shock valving (control), not so much the springs themselves.
My car has 60's a best of 1.289 footbraking, mid 9 second naturally aspirated 454 bbc, th400, 6000 flash 8" converter, th400, 4.33 gear.
Hot & greasy tracks are a big challenge for the radial tires. For this reason, I now have a second set of rims with a pair of 10.5 x 28 Hoosier stiff sidewall slicks for when conditions are at their worst.
hth
Todd
Todd Geisler is offline   Reply With Quote
Old 04-17-2008, 11:13 PM   #3
Floyd Staggs
hth
Todd
Todd,
My truck is a '68 GMC shortbed 1/2 ton that weighs 4000 lbs. It has a pump gas 540, turbo 400, ford 9", ladder bars , alston shocks in the rear, Q1's in the front.. It runs high 10's but I'd like to get it down to DGas times. In perfect weather it has gone 10:70 with the radials. I'm going to miss the Heritage race this weekend cause I didn't have any time to service it or change tires. But, in 2 weeks we have another Heritage race in Vegas and I just have to figure out if I need to change tires or suspension setup.
By the way, those are impressive times from your ride.
Old 04-23-2008, 07:46 AM   #4
donald j raiser
Smile Re: Radial tire chatter
you have a section width of 13.1, on a 10 inch rim. i would start at 18 psi, and go up not down in tire pressure. best of luck.
dj raiser
donald j raiser is offline   Reply With Quote
Old 04-23-2008, 07:02 PM   #5
SSTRACER323
SSTRACER323's Avatar
Send a message via Yahoo to SSTRACER323
Floyd,
Do you run inner tubes? I have a 3000 lbs 64 Nova in Super Street, Leaf springs and slapper bars. I was having problems with the same thing and a good friend of mine with a 71 El Camino told me to put tubes in. He had the same problem and after over $4000.00 in changes he put the tubes in and problem solved.
I run a Hoosier 28x10.5wx15 with inner tubes and no problem.... Except i lost a axle this weekend!!!!
I run 13 pounds of air in the rear. car hooks great
Hope this might help
The Doughboy
Lee Lones
S/ST 323L
SSTRACER323 is offline   Reply With Quote
Old 04-24-2008, 09:37 PM   #6
Floyd Staggs
Lee, no, I don't run tubes. I've always run MT's tubeless and never had a problem. I have softer springs coming and I'm going to up the air pressure for the coming Heritage Race in Vegas. If I can get another set of wheels before before the first of May I will take the bias tires also just in case. I'm also going to crank up the shocks.
Floyd
By the way, thanks DJ, I'm going to try the 18 lbs.
Old 09-06-2010, 10:51 PM   #7
gtnorman
i have at stk elim car and want to put radials on it,30 x 9 x15 who has the best hoosier,goodyear are my two choices.i will be running crate motor in ihra.
gtnorman is offline   Reply With Quote
