Old 06-25-2022, 11:39 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default sbc lifter bores
hi....can u safely machine sbc factory lifter bores to fit a .904'' lifter? SS application. tks
Old 06-28-2022, 06:30 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: sbc lifter bores
Yes, you can. Just make sure the cam profile is designed for the roller wheel diameter.
Old 07-03-2022, 01:23 PM   #3
richie 2
useing brass bushings correct? who has those avialable? tks ssdiv6
Old 07-03-2022, 01:52 PM   #4
SSDiv6
CHE, PPPC and Jesel.
https://www.cheprecision.com/
https://www.pppcenter.com/lifter-bore-sleeves
Old 07-04-2022, 11:09 AM   #5
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
You don't necessarily have to use bushings, although I certainly like doing so. Gives you far greater control over how much oil goes up top.
But you can just bore and then hone the block for .904" lifters without bushings.
