Old 04-12-2008, 01:00 AM   #11
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Diesel Head Gaskets O/T
The truck is back in my possession, the new short block got to the dealer ahead of
the complete long block so that is what I got along with one new head to replace the
one that popped the headgasket it was warped.
Truck seems to have much better power, etc. Going camping in one week so will
see how it does towing the travel trailer....maybe better milage??
Thanks again for everyone's imput, it all was helpful.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 04-12-2008, 10:35 AM   #12
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
philip one thing to keep an eye on is the coolant level,if the dealer didnt get all of the air of the coolant system there could be a air pocket and it may cause the egr cooler to fail,just make sure coolant level is up fyi GMONDE
Old 04-12-2008, 04:23 PM   #13
Philip Saran
Yes, I talked with the tech before I picked up the truck and that is what he said to
keep a eye on.
Thanks for bringing it up.
Phil Saran
Parker, Colorado
Old 04-16-2008, 01:09 PM   #14
crazyponcho
I do a lot of 6.0L ford heads for a nearby performance shop, custom vavle job, porting, and decking. Any way I have seen that every set of heads that come in needs at least half of the ex. seats replaced due to cracks but in general one third to half of the heads are cracked so bad that they can't be reused generally between between the injector and ex. seats. These are of running trucks to! But to solve the head gasket problems we groove the heads for o-rings and they hold up even in the engines with tuners and custom turbos. If you don't like the chevys get a dodge cummins won't be as quick empty but loaded it will out pull the 6.0L and last forever.
crazyponcho is offline   Reply With Quote
