Old 05-27-2022, 09:38 PM   #1
SBillinson
Liked 183 Times in 48 Posts
Default Re: Large 16AN Stainless Braided Hose - best cutting method
I use a Greenlee 718 cable cutter on all my braided hose including -16.
I usually sharpen the blades with a honing stone before cutting. It works perfectly on stainless and even nylon. If I get any fraying, I shape the end with the broad side of a cut off wheel.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 05-28-2022, 11:18 AM   #2
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I usually insert a wooden dowel inside the hole of the hose that is close to the diameter of the hole, not to tight but not too loose, a little white grease helps. This keeps the shape of the hose intact. Electrical tape on the outside, cut using the method of your choice, Dremel is my favorite. After the cut is made take an air hose and blow out what’s left of the dowel. WARNING: what’s left of the dowel in the hose is a projectile!
Obviously if you want to make a cut in the middle of a 12 foot hose this doesn’t work but it works great to clean up your previous cuts.
Good luck
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 05-28-2022, 11:50 AM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Tape it and air grinder with cut off wheel. Cut it direction of cutter rotation and will come out clean. Air hose to clean and ready for fitting.
Old 05-28-2022, 10:38 PM   #4
OkieRocket
OkieRocket's Avatar
Liked 6 Times in 5 Posts
Smile Re: Large 16AN Stainless Braided Hose - best cutting method
THANKS for all of the great Tips and Info. guys! I really appreciate the help!
OkieRocket is offline   Reply With Quote
Old 05-31-2022, 07:07 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Metabo or other thin cut off blade will work fine too
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 05-31-2022, 11:50 PM   #6
Jeff Stout
Do you need any 90's or straight ends? I have brand ones in the red blue color. Half of cost plus shipping.
Old 06-01-2022, 09:10 PM   #7
OkieRocket
OkieRocket's Avatar
Thanks for the "deal" Jeff, but I already have my Fittings. I appreciate the bargain though!
