#11 |
Liked 880 Times in 311 Posts
The right cast iron nose has helped with problems on a few BBC's that have come through the shop. The flywheel run out rears it's head, esp when I have a warped one on the balance. Not a good thing for balance.. I've thrown away a few that had the ring welded on elliptical. Good luck hunting down the issue.
Adger Smith (Former SS) |
#12 | |
Liked 306 Times in 172 Posts
#13 |
Liked 857 Times in 234 Posts
Yes ,I just looked at that ,don't know why I typed closer ! brain fart I guess . but the distance issue is still a possibility .
#14 |
Liked 202 Times in 87 Posts
I assume your starter bearings and starter drive are healthy. I remember a BBC block my brother and I had that did the same thing. We machined the mating surface of the starter. Not sure it solved the problem but it was much better. Don't remember how much we removed but if you go to far you can always shim back. Maybe try it with a nosepiece you don't care about (ie not a cast iron nosepiece). If you find this is the problem machine the block next time it is out so you can use any unmachined starter. Can you use a start retard device? Good luck, Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
#15 |
Liked 132 Times in 52 Posts
I used to do a lot of pulling, rebuilding and installing engines and if the the starter sounded good when driving in to pull the engine I always sent that starter out to be rebuilt. Been through that starter nightmare to many times sometime it took longer to fix the starter than it did to pull and install the engine.
Terry |
#16 |
Liked 961 Times in 351 Posts
I spent 30 years in a fleet garage (Ralston Purina) working on forklifts, power workers, semi trucks, bobcats,lawn equipment,aerial platforms, even locomotives. I can remember fighting this issue several times and finally figuring out how to cure it. These were not modified engines with aftermarket flywheels and such, but we did have similar issues. If you're sure the mechanics are correct, and your starter is fine, you might try this. We started putting a nice sized remote continuous duty solenoid and running 10 gauge wire to it, and then over to the starter solenoid, which in these engines were a part of the starter as they were GM engines. We used the original starter lead to trip the soleniod.It cured it every time. Must be some type of voltage issue, but on a meter everything showed normal. I always thought the solenoid must not have had enough force on it to hold it in tight and the working of the pinion in and out makes racket and severe vibration under load.. But all I know is it fixed it .It's a pretty cheap fix if it works. We ended up with every Clark Lift Truck in the place having one of thoses Hot Starts installed.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 01-28-2022 at 10:16 AM. |
#17 |
Liked 279 Times in 96 Posts
Some good tips here,cover all the basics first.. ''l add....flexplate straight and round...,bolts are knurled,but are they tight in starter....,there are few different sizes.... that flywheel and drive may never be made quiet once it has been roughed up...
The best way I have found to fix noisy starter is install it without the solenoid,so you can engage the drive into the flywheel and check how the teeth meshing...use pliers or needle nose,to turn the drive and check backlash... worst one I ever fixed,I had to mill the nose about .075'' to get teeth deeper... fit it to where teeth are meshed so they almost bottom out,but you still have a little backlash,can rock the gear just enough you see it has clearance you will see a huge difference in how the gears work when properly meshed,takes way less effort to turn Last edited by Mike Taylor 3601; 01-27-2022 at 09:52 PM. |
