Old 12-24-2021, 08:42 AM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Radiator?
I'm looking at an aluminum single core with plastic tanks. Anyone have any experiences to share? Post here or PM. Thanks!
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 12-24-2021, 10:33 AM   #2
SSDiv6
Default Re: Radiator?
My opinion is that is they are good for an OEM application, they should work on a drag car.
Old 12-24-2021, 11:54 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Single core is fine. Mine has aluminum tanks
Mike Pearson 2485 SS
Old 12-24-2021, 01:47 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Aluminum tank radiators are a much better choice . Structurally stronger ,
[important for wheelstand cars] and safer ,the tanks cant blow off due to a blown head gasket .
I use a lot of Champion radiators , they have a good selection of direct fit radiators for most applications . and their prices are reasonable .
www.championradiators.com
Old 12-24-2021, 02:05 PM   #5
e vassar
Liked 271 Times in 107 Posts
Smile Re: Radiator?
Last one I bought was from Speedway. All aluminum price was very reasonable.
Old 12-30-2021, 08:52 AM   #6
Liked 10,747 Times in 2,235 Posts
1986 C10 Chevy 4.3 V 6 truck came with plastic ends on a cross flow single core aluminum radiator. Very lite and last time I bought one not to bad of price.
Old 12-30-2021, 09:27 AM   #7
Rory McNeil
Liked 1,104 Times in 302 Posts
Depending on the vehicle, a replacement stock radiator may be aluminum construction, even if OE equipment was not. When I needed a new radiator for my Ford 5.0 FOX body car, the rad the local parts store carried was a light, aluminum with plastic tanks version, even though the original was all brass construction. I simply asked for a stock replacement rad for a 5.0 Mustang, and thats what they gave me. It fit perfectly in the original brackets, it cools just fine, and has a wide, single core.Plus the price was very good. It has been in the car(s) for well over 10 years, and has worked very well, even with good wheelstands thrown into the mix.
NHRA 6390 STK
M/S 85 Mustang
Old 12-30-2021, 02:39 PM   #8
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Champion radiator is hard to beat. Direct fit, and cost effective.
427FE is offline   Reply With Quote
Old 12-31-2021, 02:21 PM   #9
Eman
Liked 133 Times in 76 Posts
Been using a stock replacement aluminum with plastic tanks on my 3rd gen Camaro for over 20 years. Came from Advance with a lifetime warranty. I changed it out once for the crappy petcock leaking from winter drain and refills. I JB'd the petcock on the new one and put a drain in the lower hose.
Old 01-03-2022, 01:39 PM   #10
Don Anderson
Liked 24 Times in 8 Posts
Special thanks to Alex & Tony Denysenko & many of us got on the list to lobby N.H.R.A. to allow Ford`s replacement/superseded for Fox body Mustangs. I do still have a 3-core brass one on the shelf like new.
Don Anderson is offline   Reply With Quote
