Liked 216 Times in 77 Posts
Ok I’ll try what you suggested. But I’m going to try a box first. Heck I don’t have a spare. It’s literally the only thing I don’t have a spare of. And it’ll only take a few min to change. Drag racing. Because I hate money and love work. LOL
Still wondering how much better the tech west boxes are. Trying to decide one of those. Or just another as produced by MSD. |
#2 | |
Liked 975 Times in 311 Posts
Sounds like he’s got better. And I understand having a family member that needs you. My stepson lives close enough to take it in person and check in if needed. I’m going to give it a try.
Liked 57 Times in 24 Posts
Have you check the timing while the problem is happening ?
Timing mark is always rock solid for me . Is the ECU controlling the timing advance? What ECU are you using for the FI? Are you using a crank trigger or distributor trigger ? |
Holley yes on crank trigger. No I’ve never checked timing while it’s doing it. It sounds terrible barely running, like a blubbering flooded engine or it’s firing but way way retarded. You know it instantly if it’s doing it. I always shut it off because it sounds so bad. Like I said before click ign switch off. Right back on restart and it’s fine. One time I did click it off and pull plugs to see if it was flooding. It plugs were fine. All I can think is something occasionally happens in the box. But resets clicking it off. I’m not sure it would stay running long enough to hop out and hook up a timing light. I’ve changed everything. I really skipped the box. Because it’s been tested. I had almost resigned that I’d just keep going until whatever it is quits all together. But like I wrote before I read all those tech west posts and saw what was up with msd. And started thinking maybe that’s where the problem is after all.
Liked 19 Times in 8 Posts
Rob PM Sent
Joe Schweigert 751 SS |
