I have a 94 Camaro that i have been running in stock this year in division 2 races. I have all of the best parts from ECU, headers, engine, tranny, suspension yet the car does not seem to have any bottom end power. Could it be possible the stock opti-spark could be messed up but would still alow the car to go down the track??? really need to get this figure out thanks!!
Also car's ECU is plugged directly into stock opti-spark could it def be affecting bottom end power?? |
Liked 3 Times in 1 Post
Sean, i am not going to say this is your problem but i have seen Optisparks slow down a car 25 hundereths and never miss a lick, so that is a good place to look! The Rotors are bad about the probe turning! Go ahead while you have it down and change it over to the MSD Cap and Rotor! That is if they have it for the 94 model, i always change them over to the 95 and later!
Woodro Josey 2002 STK |
Thanks Woodro thats what i was hoping to hear. I bought one from msd at the gators but haven't put it on yet. Was way too hectic running the rounds with two cars. Thanks again def will be posting some more questions soon.
Liked 5 Times in 3 Posts
Woodro you are right they have have caused real problems at time. I would also inspect cam timing, with the limited valve to piston clearance I am not sure it could be off much. Where does the convertor flash to?
We thought it was converter so put one in that flashed 400 rpm higher right in the range were it should be as too talkin to some people. Did not help the 60 foot at all. Still no help bottom end. Another questionable factor i was thinking about as far as cam timing on the dyno the headers would turn cherry red as indicating lean but tune wasnt. Could this be in cam timing? Thanks for the input Tommy hope all is well.
The few times that I have seen the headers turn cherry red was because the ignition timing was too low. This was at an idle, and they were cherry red right next to the cylinder heads.
4878 SS/GA 66CHEVY II |
We checked the timing after the dyno and it was exactly what it should be. Plus this cherry red glow was at higher rpms like each time we made a pull.
How are you checking the timing?
Hope it's not a dumb question but the LT1's have no timing marks |
Liked 544 Times in 213 Posts
You have to make a timing pointer of some kind for an LT-1. I welded a piece onto the water pump housing and then down to the balancer. The housing is doweled to the block so it should be in the same place everytime you take the housing on and off. A crank trigger would allow you to either run locked timing seperate from the ECU or feed the signal to the ECU and plot a timing curve. I ran it locked out mostly. I used an MSD crank trigger and also their cap and rotor.
Yeah we had somethin rigged up on there to check the timing. Thanks for the info Rich ill def see what i can with that. thanks everyone
