Probably would want a steel crank with a stick though.
Liked 7,944 Times in 1,521 Posts
For what its worth, not sure there are any GOOD factory 305 blocks out there..
Liked 68 Times in 41 Posts
electric fuel pump
electric water pump electric fan all yes's
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 10,741 Times in 2,234 Posts
Cool I will put spacers in an early 360 and use a 318 crank. I dont think spacers are approved for stock.
Liked 980 Times in 197 Posts
Didn't mean to open up a can of worms but aren't most bowtie blocks large journal blocks? How do they run a 3" stroke crank in them to make them a 265 or 283?. I went through tech in 2019 with my 265 made from a 305 block and the tech guys noted it had side mounts and I told them what i had done. It was ok then?
Liked 172 Times in 81 Posts
My understanding of that rule is you can't run smaller journals the what the intended combo came with. If you're running a 265 crank in a 305 block, journal sizes are still "stock".
Jim Mantle U/V/SA 6632 |
Larry, go ahead and run your 318 crank with the spacer bearings. I wont tell anyone.LOL
Liked 20 Times in 15 Posts
thanks guys. engine not so big a deal. its the 4 speed and rear axle that are important.
Rod in AZ |
Liked 348 Times in 79 Posts
As a newbie myself, while a rule book is great, you also need specific info for your combination. Visit the classracerinfo.com site and it will give specific parts and part #'s for some things you asked about.
