Old 09-23-2021, 12:03 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Measuring for pushrod length
What method do you use for measuring for pushrod length? In the past I went with the felt tip marker on the valve tip like most of the cam companies recommend. I've read and watched videos on the 90* at half lift method but haven't tried it yet.
Old 09-29-2021, 10:22 AM   #2
Brad Hawk
Liked 2 Times in 1 Post
Default Re: Measuring for pushrod length
Are you working with roller-tip rockers or "shoe" style?
Stud-mounted or shaft?
How much lift at the valve?
Brad Hawk is offline   Reply With Quote
Old 10-01-2021, 01:44 PM   #3
Eman
Sorry for lack of info.
Stud mount full roller rockers, I have both 1.5 and 1.6, it's a small block Chevrolet. Lunati solid flat tappet small base circle cam .570/.560 lift with 1.5 rockers.
