Old 08-12-2021, 03:35 PM   #1
JCChildress
JCChildress's Avatar
Liked 11 Times in 5 Posts
Default GM Aluminum Heads
Did GM ever produce any performance based 23 degree, aluminum heads ? If so....how were they ?
JCChildress is online now   Reply With Quote
Old 08-12-2021, 03:51 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: GM Aluminum Heads
GM #19300956 FAST BURN HEADS ---other wise everything was 18-15-12 degree- no idea how they worked no experience with them
Old 08-13-2021, 08:23 AM   #3
Henrys Toy
Liked 520 Times in 176 Posts
Good morning ,
In "as cast" condition, most of GM's cylinder heads ( stock or performance) are not to spectacular, flow wise. Quality of the castings are very good. The machine work from the factory is good, I would still strip them down and check your clearance's. In a performance application I would install bronze guide liners and perform a multi angle valve job on both intake and exhaust valves and seats..
The biggest operation is making sure the valve springs match the camshaft that you would be planning on using, be sure to get the open and close pressure's corrected. Also making sure the retainers clear the top of the valve guides and seals for the lift the camshaft will be opening.
Then check and equalize your combustion chamber CC's .
That's my two cents worth, new castings with up to date improvements are money well spent.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 08-13-2021, 03:34 PM   #4
Pat6868
Liked 88 Times in 28 Posts
113 corvette head, also used on ZZ4.
Pat6868 is offline   Reply With Quote
Old 08-13-2021, 07:49 PM   #5
FED 387
AS I SAID the fast burn head ---same head as on ZZ4
Old 08-14-2021, 11:45 AM   #6
Pat6868
113 corvette(ZZ4) and 956 fast burns are not the same.
Old 08-14-2021, 01:24 PM   #7
ron mattson
Liked 68 Times in 31 Posts
The Fast Burn heads are decent out of the box
but with a little work on the short side they become
Stellar!
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 08-15-2021, 08:26 PM   #8
JCChildress
What intake works good with them, on say a 327 super stock type engine ?
