08-09-2021, 10:27 AM | #1 |
Liked 2,752 Times in 862 Posts
24 Foot EZ Hauler Aluminum Trailer
Purchased new in March 2021 from Trailers of the East Coast and have only used for transporting to Gainesville for two test sessions and Galot D2 race in September. Originally purchased 24 ft aluminum due to plans to pull behind gas Class A and was trying to keep weight down Now going a different direction and need a 32' with bathroom package. 60" tongue for towing behind motorhome. Below are the other specs, only drawback is the 32" entry door but is wide enough to get the scooter in and out. I've added a couple of anchor points to secure the scooter but no other changes.
Weighs only 2700 pounds! Easy pull behind almost any 1/2 ton or small motorhome. • All-Aluminum Construction, Integrated Frame Design • Front Style: Flat Front w/Cast Corners • 2″ x 5″ Integrated Frame (16′ to 20′) • 2″ x 6″ Integrated Frame (24′) • 2″ x 8″ Integrated Frame (28′ to 32′) • 16″ O/C Floor & Roof Studs • 16″ O/C Wall Studs • Screwless .030 Bonded Sides • One Piece Aluminum Roof • Axles: 2-5.2K Braked Leaf Spring Axle w/ 4″ Drop 15" Aluminum wheels (225/75) • 24″ Stoneguard • 2 5/16″ Coupler w/Safety Chains • 5000lb Center Jack w/Foot • White Vinyl Faced Luan Walls • 3/4″ Water Resistant Decking • Interior Cove Trim • 3″ Exterior Trim • (2) Dome Light w/Switch • Exterior LED Lighting • Plastic Salem Vents • (4) HD 5,000# Recessed D-Rings • Beavertail Construction • HD Rear Ramp w/Spring Assist w/Aluminum Hardware • Large Side Door with removable inner fender to easy egress from car • 4-Year Limited Warranty PM for pics or other info. Title in hand, located in Savannah GA area and price is 20K
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Last edited by jmcarter; 11-04-2022 at 08:08 AM. |
