Liked 166 Times in 71 Posts
I recently acquired some BB Mopar parts and among them is a pair of heads I’m having a hard time identifying. The heads have the direct connection emblem cast into them and a casting number of 3714476. They came with valve covers that have “Mopar Stage IV” on them. These are a little bit out of my realm so any help to ID is appreciated
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 25 Times in 16 Posts
3614476 – MOPAR Stage IV, B/RB-series big-block, 2.08/1.74 valves, legal MW replacement for the 1964 (and maybe other) MW heads in NHRA.
4532287 SS only – MOPAR Stage V, B/RB-series big-block, 2.08/1.74 valves, 906 type replacement head.
Mopar 2 Ya! |
Liked 272 Times in 142 Posts
The Stage IV was an over the counter replacement head Direct Connection sold in the late 1970-s, through the early 80's. They are standard port window, not Max Wedge port window, and they require a special offset intake rocker (more than stock, but not as much as Max Wedge). I believe the offset is .100 more than stock. They are slightly better than a "452" casting, but not as good as a Max Wedge head out of the box.
#4 | |
Liked 307 Times in 116 Posts
Liked 54 Times in 8 Posts
I had a set of stage IV heads back then. If I remember correctly, they require some push rod clearanecing on the outside of some of the intake ports. I think one of the old Direct Connection bulletins had instructions on what was required.
Liked 2,610 Times in 948 Posts
If my memory is correct the Stage IV heads weren't worth a damn out of the box and required a lot of work, and even so were not as good as a 518 head.
I'm sure Don Little's expert opinion would be worth much more than mine. Also Al Corda could offer his as well. Last edited by Frank Castros; 07-28-2021 at 07:08 PM. |
Liked 172 Times in 53 Posts
Max wedge heads absolutely require an offset rocker if you are running an aftermarket rocker like a T&D or Jesel. The OE rockers have an angled tip and don't require it. The aluminum rockers do not. For that matter an ordinary RB/440 head also requires an offset exhaust rocker.
