Old 06-17-2021, 11:48 AM   #6
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Default Re: Data Logger Worth it or Not?
The Racepak Sportsman appears to be the entry level unit. Their website states that out of the box it will record:
Engine RPM
Drive Shaft RPM (Requires Driveshaft Collar Sold Separately)
Accelerometer G-Meter
Lateral G-Meter
Battery Voltage
12 volt event
Record Button
What information would you gain from these inputs? Wheel slip, acceleration rate, missed shift RPM?
What else would need to be added to that system when used on a carbureted stocker?
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
