Old 04-22-2021, 11:42 AM   #3
Darcy Clarke
Liked 594 Times in 38 Posts
Default Re: O2 sensors
As a guy that runs 3 multi-carburated cars I have found both on the dyno and on the track to truly tune you need one in each primary. The collector O2 work but is an average of 4 cylinders and you can still.be way off. If you do run 8 make sure you have lots of battery reserve!!
Darcy Clarke
6254
SS/EA A/SA
Darcy Clarke is offline   Reply With Quote
