#1 | |
Perhaps a little more clarification is in order. So, if you have a race car that does have an alternator, but you use a fan and water pump to cool it between rounds, while having a 20 amp 14 volt charge, which battery do you use? Especially if in later rounds you have a short charge time AFTER you turn off the water pump and cooling fan.
Alan Roehrich 212A G/S |
Liked 557 Times in 217 Posts
I've used red tops for 20 years or more.
Always had an alternator and use fan and water pump between rounds with a 10 amp charger usually hooked up. I've never had a red top fail in any car. I did have one that I removed from racecar and was using in a camper go bad but it was at least 7 years old. I've seen yellow tops go bad without warning..... I replaced a red top in my car last year and it says 2013 on it.....It's still good....
