Old 02-02-2021, 12:16 AM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default I'm going to build a smooth idle 427 and drag test it
4.350 X 3.764 447 CUIN, I will use a Racetech piston with a 1.5 1.5 3.0 MM ring pack, compression will be set at 9.7. The center piece of my build will be a copy of a GM 350 HP 396/390 HP 427 hyd cam. My buddy @ Redline will grind it on a original 1960s GM cam core, I will have the LC changed from 115 to112, specs are 460/480/216/218/112, the goal is a dead smooth idle with complete reliability. Spring pressure will be set @ 120/300.
Comp Cams roller tipped rockers will be used with .083 wall moly 3/8 pushrods. I have new 1970s TRW hyd lifters to go on the cam. I used 1971 820 GM oval port heads (only because I had them) honed bronze valve guides, chambers cut on the exhaust side, 1.880/2.190 Ferrea valves installed, fully ported, surfaced and CCs set. For a intake I used a unmodified factory GM cast iron Q-Jet intake of course with a Q-Jet for the carb with a 1inch phenolic spacer. My two carbs were built by Harold Betttes and Vintage muscle car. I used a 402 cast crank with worked over GM rods, everything was balanced. My goal here was to run low 11s in my 68 Chevelle on pump gas with a dead smooth idle, why I have no idea.
ID:	56685   Click image for larger version
ID:	56686   Click image for larger version
ID:	56688   Click image for larger version
ID:	56689   Click image for larger version
ID:	56691   Click image for larger version
ID:	56692   Click image for larger version
Old 02-02-2021, 09:19 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: I'm going to build a smooth idle 427 and drag test it
What type of block and what was it honed on, can you list the head flow.
Old 02-02-2021, 09:44 PM   #3
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
I love it! following. Whatever happened with the Buick?
Old 02-02-2021, 10:13 PM   #4
Liked 5,151 Times in 1,966 Posts
Cool.. Only one question at the moment...Pueblo or Kearney?
Old 02-02-2021, 11:01 PM   #5
HP HUNTER
New engine built, hav'nt run it since the wuhan virus. You can't except PMs. Send me your number and I will fill you in tomorrow. Or send me your Email.
Old 02-02-2021, 11:08 PM   #6
HP HUNTER
959 production 454 block
280 grit hone, looks funny wet with hone oil
820 head castings, SF 600 4.350 bore @ 28 inches, Intake flow
.200 156
.300 225
.400 276
.460 292
.500 301
.550 312
The 820 casting is down on flow compared to other GM oval port castings, but I had them so they were used.
ID:	56717   Click image for larger version
ID:	56718   Click image for larger version
ID:	56720   Click image for larger version
Old 02-02-2021, 11:18 PM   #7
HP HUNTER
No thanks...............Houston Actually I'am really looking for high 10s with a smooth 750 RPM idle.
Old 02-03-2021, 08:50 AM   #8
HP HUNTER
More pictures
ID:	56722   Click image for larger version
Old 02-03-2021, 01:49 PM   #9
MR DERBY CITY
Liked 8,221 Times in 1,538 Posts
Nice, but where are the oil pan pics ?? ......LOL. .....
Old 02-03-2021, 09:50 PM   #10
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
No concerns going +.100 over with a production 2 bolt main block ?
