Liked 275 Times in 76 Posts
VP C-16 is what I run in my SS 84 2.3 turbo Mustang. Not cheap but it works and has never had any issues passing fuel check. I buy a barrel, and transport what I need for each race. I believe that is what the other guys running this combo in stock are also using. We also own a 2016 Ecoboost Mustang, in sport mode it will product over 32-34 lbs of boost. Don't shoot yourself in the foot by not running the right fuel for a turbo combo. As for O2 sensors, I replace mine every season as preventative maintenance. I do not see any change in performance after changing out the sensor.
Stick or auto? If you delete emissions stuff and get the weight down to minimum, that combo will run well under the index. What are you planning on doing for engine management? Sean
Liked 117 Times in 50 Posts
We're thinking about a VERY basic combo. Stock engine, stock computer, stock converter, and stock rear end gears. Baer SS4 front brakes, 15" Bogarts, mandrel-bent 3" open downpipe, rear O2 spacer, an aftermarket tune, the required safety equipment, and a fuel tap per the rules for fuel testing. If it won't run under, then maybe a converter for the stock 6R80 automatic transmission.
Frankly, I'm thinking of DOT drag tires, license plates, and liability insurance, to avoid the cost of a truck and trailer. It should get at least 30 mpg on the highway. For any race that is any significant distance away, we can rent a U-Haul truck and open car trailer. Last edited by 6130; 12-29-2020 at 10:24 PM. |
#3 | |
Liked 251 Times in 125 Posts
I broke an axle on the starting line. The starter said, "Well, it hooked". Yep, and all of the money flew out of my wallet, because of that hook. Last edited by Dave Gantz; 12-29-2020 at 10:39 PM. |
Lund is one of the most likely sources of a tune.
The K/SA index is 12.65, and the current I/SA record is 10.93. There are plenty of these cars running mid-11s with stock engine/turbo/converter/gears/brakes and heavy wheels/tires... Last edited by 6130; 12-29-2020 at 11:45 PM. |
Is Lelchook's car silver? I saw a video of a 9.45 @ 146 lap that looked like a street car.
He's reportedly been 11.29 @119 and change on a stock engine and stock turbo... |
Yes, it is Silver. It went quicker than 11.29 on street tires and 93 octane pump gas with stock exhaust and OEM weight.
Liked 240 Times in 112 Posts
I'll throw 2 cents in on this. I don't have a turbo car but I have used C10 & 260GTX with an O2 sensor. And I've tried to use an O2 with leaded fuel. While in my case the lead did not "Kill" the O2 sensor, it Did make it lazy. On a different vehicle that I just worked on, Leaded fuel "Murdered" 4 O2 sensors. I don't know the brand of fuel (or the brand of sensor) but it ran at Bonneville @ least 10 years ago.
Dave Noll, EF/S ,?/SA 6526 |
#8 | |
He has been flogging his Ecoboost Mustang for sometime and has gathered lots data and done many mods at different stages. He has been working with Lund Racing and others. He drives his car to the track and has made passes in the 9.80's @ 140 MPH. He has a dedicated page in Facebook under "Ecoboost Mustang Drag Racer". |
#9 | |
Liked 372 Times in 130 Posts
I had thought of this combo in 2018 to update from my " Pinto based " 2.3 Turbo. Buying the car and bolt-ons was going to run 30K. Plus taking out the interior for the roll bar.I think I'll wait. FWIW....not sure how different the O2 sensors AEM sells for their Wideband O2 gauges are from the OEM Ford versions, but I have been running one for 7 seasons using VP C16 and no issues
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 01-04-2021 at 01:44 PM. |
