Old 12-20-2020, 01:02 AM   #2
SSDiv6
Liked 1,580 Times in 582 Posts
Default Re: Bearings/lube
Originally Posted by Adger Smith View Post
There are a couple of threads on here about wheel bearing lube and rear gear lube.
That just brings up something I have noticed and am wondering what others think.
I have owned several cars built by others.
I have noticed that on the rear axle some have the wheel bearing's inner seal removed, others run with the bearing "sealed".
Anyone have any thoughts?
Adger,
Sealed axle bearings are used in many applications. FWD cars and late model cars with struts have sealed bearings that last for a long time. Non sealed bearings require additional lubrication just like in rear axles. What I have done in the past with sealed bearings is to pop out the seals, wash out the grease and replace the the original grease with a high end synthetic grease and put back the seals.
