Old 12-13-2020, 02:08 PM   #1
GTOMayhem
Liked 22 Times in 14 Posts
Default Re: PVC and catch can question
I understand PCV valves allow varying degrees of vacuum depending on engine application. There is even an adjustable one. Someone with more knowledge than me will need to fill in some details, though. Also, I think Billy Nees just runs a vacuum brake booster check valve as a PCV. He will need to fill in the details.
Rick Thomason
GTO Mayhem
GTOMayhem is offline   Reply With Quote
Old 12-13-2020, 04:10 PM   #2
SSDiv6
Liked 1,572 Times in 580 Posts
Jeff,
You have options.
You can put a Wix crankcase breather filter, P/N 46978, between the valve cover and PCV or breather.
https://www.wixfilters.com/Lookup/Pa...px?Part=138224
Another option are Speedway Motors PCV Grommet Baffles.
https://www.speedwaymotors.com/PCV-G...Caps,7332.html
Or, weld tubes on the valve covers and put breathers.
Old 12-13-2020, 08:34 PM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Jeff,
You have options.
Thanks Joe. I ordered the grommets from Speedway
