Old 12-06-2020, 04:50 PM   #41
Adger Smith
Liked 880 Times in 311 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
I forgot about the water pump. My V-6 is a Cam trigger and the magnetic pickup is on top, behind the water pump. I had a pump start leaking as we were loading the car. When we got to Ennis we made one run with a towel taped to the pump. It was leaking too bad so I took the Cheaper brand pump I carried as a spare and put it on. The car popped and missed at high RPM. We looked at plugs and ignition and all the electrical. We had one more shot of qualifying left and as I was doing my burn out the car popped on the chip... It hit me that the pump was what we changed and the problems cropped up. As I staged I turned the pump off. Good run, no 9000 RPM miss. Got back to the trailer and took the other pump apart and robbed the seal out of the electrical gremlin pump. Finished the race with no pump or miss problems. I figure that pump motor was a small radio station tuned to my ignition frequency. It wasn't playing any tunes my ignition liked...It seems like the simplest fixes can be the hardest!
Adger Smith (Former SS)
Old 12-06-2020, 05:16 PM   #42
Lee Valentine
Liked 319 Times in 68 Posts
we had a bad ground on electric water pump slow us down one time.
Lee Valentine 1661 STK
Old 12-06-2020, 05:25 PM   #43
Robin Lawrence
Sponsor
Liked 716 Times in 120 Posts
You stated earlier that you changed the ignition box and it picked up on one run. Then it returned to the loss of mph and ET.
What box are you running?
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 12-06-2020, 07:15 PM   #44
Bill Marshall
Liked 53 Times in 24 Posts
Robin
The car has a MSD 7AL-2
Bill Marshall is offline   Reply With Quote
Old 12-06-2020, 07:19 PM   #45
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by monte8616 View Post
What else do you know about the magnetized thing? Very interesting...
Make sure the dist pickup wire is away from the other wires, I use a shielded pick up wire.
Old 12-06-2020, 08:33 PM   #46
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: LOST 10mph AND ABOUT 6 TENTHS
our car slowed down over a couple of races. Turns out it was the rubber brake line to the rearend swapped out line at track and picked up instant 5 tenths.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 12-06-2020, 10:03 PM   #47
4543
Liked 647 Times in 140 Posts
Can you post a net slip from both a fast and slow run? Can you post the race pack info from a good run with a bad one overlaid on it? What sensors do you have on the trace pack? Other thing would be send the race pack files from a good run and a slow one to someone you know who has been using a race pack for a while. Might pick up something.
4543 is offline   Reply With Quote
Old 12-06-2020, 10:44 PM   #48
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
I would look at the rear brake hose. I have seen more than one collapse internally and hold the rear brakes on.
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 12-07-2020, 07:28 AM   #49
Steve Hurley
Liked 4 Times in 2 Posts
We had a power surge from the alternator, lost et chased our tail, replaced ignition box. First pass was good, and down hill from there. Replaced box again. One more good pass and then fell off again .5 to .6 . In our case it was the alternator.
Steve Hurley is offline   Reply With Quote
Old 12-07-2020, 10:00 AM   #50
Henrys Toy
Liked 520 Times in 176 Posts
Originally Posted by Bill Marshall View Post
If the engine ran good on the dyno , then what parts are different between the car and the dyno ? Usually the dyno has it's own ignition box and it's own fuel system . Maybe check these two systems out to start with .
We took the coil and ignition box out of the car and ran it on the Dyno made good power[/QUOTE]
Over the course of time the two things that would kill my car was a bad MSD box or a broken converter!
I had a Sprague break in my old Trans Torque converter , that I sent to Mike Munsinger at the time and he said the converter was good - put it in the car - still slow.
I finally sent the converter to Coan , they found a broken sprague , fixed it
Result - car fast again! These bloody things will really make you chase your tail.
Try a converter from a friend ,hopefully a known good piece, I think you might just find the "cure". Bill you might remember my MSD problem from Lebanon Valley a few years back, my car was slow and you said it didn't leave like it used to. We changed a bunch of stuff ( including the converter ) then last time shot on Saturday morning Glenn and I put spare MSD and coil , Result - car fast again. Engine never missed or did anything outwardly stupid just not fast.
I hope this helps, we have all been down this path!
Henrys Toy is offline   Reply With Quote
