Old 12-05-2020, 08:28 PM   #1
MR DERBY CITY
Liked 7,792 Times in 1,496 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Originally Posted by monte8616 View Post
Did the fuel system test - all good - the welding is an interesting thought... batteries are pretty new - Racepak shows all good with fuel pressure... but something to think about with the volume - thanks everyone! Keep the ideas coming!!
Just curious, how much did it pump in 30 seconds,.....carry on....
MR DERBY CITY is online now   Reply With Quote
Old 12-05-2020, 08:29 PM   #2
monte8616
Liked 14 Times in 6 Posts
Gallon in 18 seconds so volume is good
monte8616 is offline   Reply With Quote
Old 12-05-2020, 08:35 PM   #3
Jeff Stout
Liked 704 Times in 281 Posts
Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.
Jeff Stout is online now   Reply With Quote
Old 12-05-2020, 08:44 PM   #4
monte8616
I don’t have an O2 sensor yet either... we did the new plugs and wires too! Brand new MSD too lol - what’s interesting is that we originally thought that it was the MSD box because when we changed the box and made a pass, it went back to what it should’ve been running - then, after that, it went back to being slow again... ugh
Old 12-05-2020, 10:19 PM   #5
Bill Marshall
Liked 53 Times in 24 Posts
[QUOTE=Jeff Stout;629310]Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.[/QUOTE
Jeff This car use to be fuel injected and it still has the high pressure pump in it with regulator to knock down the pressure. regulator is set at 7.5 lbs also we dyno'd the engine and it still has the same power from when it was built
Bill Marshall is offline   Reply With Quote
Old 12-05-2020, 10:37 PM   #6
rognelson777
Liked 135 Times in 74 Posts
grounds. disconnect, add serated washers and no lock nuts. nylon in locknut can melt from cranking engine when wire gets hot.
fuel lines. any rubber can actually close down and limit flow when hot
rognelson777 is offline   Reply With Quote
Old 12-05-2020, 11:34 PM   #7
Chuck Gallagher
Liked 134 Times in 28 Posts
I agree, grounds are most likely weak.
Run a redundant ground wire from the side of the engine block back to the battery ground. Or, if your ignition box is inside, as most are, to the ground that is common with the ignition box and battery.
Use a good size wire and a star washer under the connector at the block.
Also, if you don't have a good size ground wire from the box to the battery negative post put one in.
Grounding to the chassis is always a crap shoot in a race car and the root cause for the majority of electrical problems.
Good Luck
Chuck Gallagher
I should have said this about engine block grounding. The most important task your battery does in your race car is provide a steady, high level of amps (current) to your ignition system. Racers in all forms of motor sports have been able to make more power over the decades by putting more fuel and oxygen inside the combustion chambers and completely igniting that mixture with higher power spark across the plug gap from the coil. The power (amps) of those sparks will never be greater than the resistance of the current path from the threads (ground side of the plugs) of the spark plug back to the negative post of the battery.
A weak engine to battery ground path does not always produce engine miss, usually just incomplete combustion resulting in less power.
Chuck Gallagher is offline   Reply With Quote
Old 12-06-2020, 10:07 AM   #8
monte8616
Smile Re: LOST 10mph AND ABOUT 6 TENTHS
Good Luck
Chuck Gallagher
Thanks so much! Think we will be taking this car apart almost completely to check it all out!!
Old 12-06-2020, 12:19 AM   #9
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
[[/QUOTE
Jeff This car use to be fuel injected and it still has the high pressure pump in it with regulator to knock down the pressure. regulator is set at 7.5 lbs also we dyno'd the engine and it still has the same power from when it was built[/QUOTE]
If the engine ran good on the dyno , then what parts are different between the car and the dyno ? Usually the dyno has it's own ignition box and it's own fuel system . Maybe check these two systems out to start with .
Old 12-06-2020, 09:24 AM   #10
Liked 10,655 Times in 2,211 Posts
Does the car have a timing retard box. I hade one go bad. I had the box checked, MSD said it was good. Hooked up box and car was slow, removed box and the car was fixed.
