Old 12-02-2020, 11:42 PM   #11
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: Are there any GM Techs out there?
We have always put a hose loop so that coolant flows as the engineers designed it. It is almost easier to remove the exhaust manifold to get to the thermostat. We have put are temp gauge fitting in the flat spot by the hose outlets. There is a bolt holding the tube from the thermostat to the water pump, push the tube into the pump there is a o ring on it the twist and remove. Tom
Tom Meyer 5240 SS Stock ???
Old 12-03-2020, 08:16 AM   #12
Billy Nees
Liked 7,891 Times in 1,753 Posts
Tom, where did you put the "hose loop"?
Billy Nees 1188 STK, SS
Old 12-03-2020, 09:28 PM   #13
Tom Meyer
We just looped the heater hoses using a u shaped formed hose with one 3/4 the other end is 5/8. We have been running these motors for the last 8 years, 4 IMCA national dirt championships and 4 UPs. Been to tech [top 4] about 600 times, one guy told me I brought to much stock / super stock mentality to the class. Tom
Old 12-05-2020, 05:28 PM   #14
Billy Nees
Alright, I am pretty sure that I've got it. With the thermostat closed, coolant goes through the heater core and into the rear of the block and is circulated through the block and head by the water pump. When the thermostat opens, water goes into the LOWER radiator hose AND through the block and head. It goes through the radiator and into the UPPER radiator hose where it is circulated through the block and head until the thermostat closes . Clear as mud....
OK, I just got finished getting "verbally abused" by my engineer buddy about the laws of physics. So I'm going to start from scratch about how this thing flows.
The coolant goes FROM the rear of the block and through the heater core. It then flows over the hot side of the thermostat and into the water pump where it circulates through the block and head. When the coolant flowing through the heater core and over the hot side of the thermostat gets hot enough, it opens the thermostat letting cold coolant from the radiator flow past the COLD side of the thermostat into the water pump( the thermostat really IS backwards!). Suction from the pump pulling cold coolant from the radiator (lower hose) lets hot coolant go from the top of the head (upper hose) into the radiator...
This is as clear as mud!
Old 12-05-2020, 08:23 PM   #15
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
GM has standards for heater performance, so heating up coolant quickly so the heater provides heat to the passengers is a high priority . Included in that is they don't want to shock the block and heads with cold coolant ,so the special thermostat was developed . I believe its similar to the older LT1 style thermostat .
