#1 | |
SECTION 11A: STOCK CARS: 1, BLUEPRINTING (Page 2) (12/3/2020) Permitted per NHRA Specifications available from NHRA Technical Services Department headquarters. Stock factory OEM Components (unless otherwise specified) must be retained and remain unaltered (i.e., cylinder heads, connecting rods, pushrods, crankshaft, etc.). Clear as mud especially when aftermarket cylinder heads are allowed. |
#2 | |
Liked 302 Times in 73 Posts
#3 | |
Liked 735 Times in 386 Posts
Liked 73 Times in 36 Posts
There are some heads out there that have been welded prior to reshaping. Cylinder port volume varies a great deal on castings, but can be closely controlled after being "tuned up" as it were.
![]() Although such things might be beyond the regular guy's interest or budget, others have done so (paid to have it done). ![]() Regards, HB2 ![]() Dissident |
#6 | |
B) if you read that and ignore the cylinder head addition it clearly deems literally every single Stock Eliminator car illegal... name me one single car that is running Stock factory OEM unaltered pushrods... in addition to that find me the rule that says we can even run larger diameter or thicker wall pushrods. At least there is a whole section on what can and cannot be done to cylinder heads. The Blueprinting rule is written to basically say you can only use aftermarket parts when they are listed on the "NHRA Accepted products list" otherwise you have to use OEM unaltered pieces. We all know this isn't the case based on the multitude of rules that follow this statement so them adding cylinder heads to the verbiage doesn't make any sense and unless they can explain to me what it actually changes in application means absolutely nothing.. now that we had this little tangent about a rule "change"... i'd like to try and steer this post back on topic... Other than flow holding past max vlave lift and a quiet port are there any specifics you're looking for from head A to head B to determine one is a .500 under head and one is a record setter? I want to restate.. I'm not looking for the HOW you did it or what you did to to find the best cores to start with...I simply want to have 3 sets of heads.. all starting from an equal "these three heads are the BEST i can find" -Head A stock completly untouched -Head B has flow characteristics that make me feel like it will be okay (.5 under) -Head C has flow characteristics the make it a record setter Knowing all 3 heads will pass tech what does Head C's flow numbers, port velocity, or anything else you can use to analyze a head on paper look like that makes it the one you chose over Head B.. Again physical things done to the head I'm not asking about. If I handed you the flow printout of 2 separate heads ported by 2 separate people and told you to pick the one you thought would be fastest cause you were headed to INDY tomorrow what is the most important thing on that print out that would sway you to pick one over the other. Or how do you rank the things you look at when making that choice.. as I'm sure it's not just one thing going into that decision. This might be too much to ask as I'm sure there are many people out there that probably make a bunch of money knowing why stuff goes fast and what their intended goal is when they flow something to know they've got a winner, but if someone is willing to talk about it that's why im asking.. Thanks Brad |
Liked 880 Times in 311 Posts
Sure looks like my old Boss has been at work on the rules.
Giving a little and taking a little with things camouflaged. LOL WR Brad, You would need to send me a little more info than 2 flow sheets.
Adger Smith (Former SS) Last edited by Adger Smith; 12-05-2020 at 08:51 AM. Reason: Add |
