#1 | |
Liked 302 Times in 73 Posts
Curious what you man by "optimize the valve open and closing events" when it comes to the valve job or flow characteristics of the cylinder head. Maybe I'm just completely naive, but wouldn't this been completely controlled by camshaft design after you already know the flows and velocities of the ports?
Liked 10,968 Times in 2,261 Posts
On the V6 truck engine I went to core suppliers to get the best sets of heads for each approved casting number. How I judged the heads by valve protrusion into into the chamber. I bet I looked at 200 + pairs of heads. I think I had 4 or 5 sets of heads of each casting number to clean and test on my flowbench. Most of my winnings from Atlanta were used to buy the bench Jimmy Bridges did my first set heads for the truck. I think he picked the two best out of six.
Liked 226 Times in 137 Posts
You want a port that continues to flow well past your max lift point and not go turbulent and is quite on the bench!
#5 | |
How far past max lift would you like to see it "flow well" .050?.0100? more? and by "flow well past" do you mean the CFM should still be increasing or just not backing up a lot? if it just holds the peak CFM from say .350-.500 at a fairly constant CFM but isn't gaining anything or dropping off at all is that okay? Thanks Brad |
#6 | |
It needs to be on the flow bench and the quietness is the sound of the air. Usually test 0.100" ~ 0.150" past your required maximum lift and don't worry about the behavior past that limit. |
Liked 73 Times in 36 Posts
Folks interested in flow bench testing:
![]() These days I can't hear worth a dip, but I do know a fair amount about flow bench testing and there are multiple ways to discern the stability of airflow in the cylinder head or manifold without hearing.... ![]() The cylinder head should be tested with the manifold and carb/throttle body attached so the "real" flow test is indicative of what the system is doing. ![]() Regards, HB2 Dissident |
Liked 22 Times in 14 Posts
I’m not a head guy but with the valves hight in the head, if you had to sink one to get the cc’s correct it usually didn’t hurt the flow real bad. In most of the old cast heads one or two runners are just turds and are difficult to get to respond. I have made a few test valves.
#10 | |
Seen too many heads with big flow numbers and low velocity that do not make power. Your valve job angles are also critical and different for each head manufacturer. The reason why you want to have a good flow past your maximum lift is because you can make more power by doing a controlled loft of the valve past your maximum allowed lift. The cam lobe is designed to toss the lifter and increase valve lift to make more power while still checking legal during a static lift inspection. |
