Old 12-02-2020, 06:16 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Re: Are there any GM Techs out there?
Straight from GM service manual that makes it as clear as mud lol.
The cooling system's function is to maintain an efficient engine operating temperature during all engine speeds and operating conditions. The cooling system is designed to remove approximately one-third of the heat produced by the burning of the air-fuel mixture. When the engine is cold, the coolant does not flow to the radiator until the thermostat opens. This allows the engine to warm quickly.
Cooling Cycle
Coolant flows from the radiator outlet and into the water pump inlet. Some coolant flows from the water pump, to the heater core, then back to the water pump. This provides the passenger compartment with heat and defrost capability as the coolant warms up.
Coolant also flows from the water pump outlet and into theengine block. In the engine block, the coolant circulates through the water jackets surrounding the cylinders where it absorbs heat.
The coolant then flows through the cylinder head gasket openings and into the cylinder heads. In the cylinder heads, the coolant flows through the water jackets surrounding the combustion chambers and valve seats, where it absorbs additional heat.
From the cylinder heads, the coolant flows to the thermostat.The flow of coolant will either be stopped at the thermostat until the engine reaches normal operating temperature, or it will flow through the thermostat and into the radiator where it is cooled. At this point, the coolant flow cycle is completed.
jamie2370 is offline   Reply With Quote
Old 12-02-2020, 07:31 PM   #2
Billy Nees
Alright, I am pretty sure that I've got it. With the thermostat closed, coolant goes through the heater core and into the rear of the block and is circulated through the block and head by the water pump. When the thermostat opens, water goes into the LOWER radiator hose AND through the block and head. It goes through the radiator and into the UPPER radiator hose where it is circulated through the block and head until the thermostat closes . Clear as mud....
Billy Nees 1188 STK, SS
Old 12-02-2020, 08:27 PM   #3
jamie2370
Billy, sometimes I think even GM doesn't know how it works lol. I have followed some of their diagnostic trouble trees for certain trouble codes that say , Step 1... replace this part Step 2... does code reset Step 3.... if yes replace this part Step 4...Does code reset, if yes, refer to Step 1
Old 12-02-2020, 11:42 PM   #4
Tom Meyer
Liked 354 Times in 120 Posts
We have always put a hose loop so that coolant flows as the engineers designed it. It is almost easier to remove the exhaust manifold to get to the thermostat. We have put are temp gauge fitting in the flat spot by the hose outlets. There is a bolt holding the tube from the thermostat to the water pump, push the tube into the pump there is a o ring on it the twist and remove. Tom
Tom Meyer 5240 SS Stock ???
Old 12-03-2020, 08:16 AM   #5
Billy Nees
Tom, where did you put the "hose loop"?
Old 12-03-2020, 09:28 PM   #6
Tom Meyer
We just looped the heater hoses using a u shaped formed hose with one 3/4 the other end is 5/8. We have been running these motors for the last 8 years, 4 IMCA national dirt championships and 4 UPs. Been to tech [top 4] about 600 times, one guy told me I brought to much stock / super stock mentality to the class. Tom
Old 12-05-2020, 05:28 PM   #7
Billy Nees
OK, I just got finished getting "verbally abused" by my engineer buddy about the laws of physics. So I'm going to start from scratch about how this thing flows.
The coolant goes FROM the rear of the block and through the heater core. It then flows over the hot side of the thermostat and into the water pump where it circulates through the block and head. When the coolant flowing through the heater core and over the hot side of the thermostat gets hot enough, it opens the thermostat letting cold coolant from the radiator flow past the COLD side of the thermostat into the water pump( the thermostat really IS backwards!). Suction from the pump pulling cold coolant from the radiator (lower hose) lets hot coolant go from the top of the head (upper hose) into the radiator...
This is as clear as mud!
Old 12-05-2020, 08:23 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
GM has standards for heater performance, so heating up coolant quickly so the heater provides heat to the passengers is a high priority . Included in that is they don't want to shock the block and heads with cold coolant ,so the special thermostat was developed . I believe its similar to the older LT1 style thermostat .
