Old 11-01-2020, 12:50 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Winters Shifter Adjustment...is killing me!!
Originally Posted by OkieRocket View Post
Thanks for the info. Lew. I had to mount the ball and the Cable on the "outside," so I could route the shift cable through a welded in tube that runs through my crossmember, otherwise the cable would be in a bind (side-to-side).
Although I see that Winters shows the ball and Cable on the "inside" of the brackets, respectfully Lew, I don't see how that would necessarily make any difference, as both are on the same "center-to-center distance".....I may be all wet Lew, but I don't see how the ball and Cable on the "outside" would cause my problem.
......Still trying to figure things out.
Thanks for your responses.
If you remove the shift lever check to see if the rectangular hole is at a slight angle . If it is then that's why you want the ball to the inside since the angle of the lever front to back will change .
