Old 10-13-2020, 06:03 PM   #1
OkieRocket
OkieRocket's Avatar
Liked 6 Times in 5 Posts
Default Re: Rivets: Steel or Aluminum?
THANKS for all of the great information! I really appreciate you guys....The true Racers!
OkieRocket is offline   Reply With Quote
Old 10-13-2020, 10:38 PM   #2
House of Darts
Liked 20 Times in 15 Posts
Dissimilar metals cause electrolysis. You can screw up your project.
House of Darts is offline   Reply With Quote
Old 10-14-2020, 11:14 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Yes, but this is more true of stainless steel and aluminum than regular carbon steel and aluminum. Water must be in contact with both metals to create this "battery" effect so I don't really think it's an issue with a race car. Using aluminum rivets on the aluminum panels would mean trading the risk of corrosion for the risk of vibration failure.
Dale Shearon
68 Mustang 6394
Old 10-14-2020, 03:17 PM   #4
SSDiv6
You do not need water to create on dissimilar materials; it can be reactive. As an example, when steel fasteners are used to affix Carbon Fiber parts or components, the carbon will cause steel to corrode. The proper way to affix CF parts is to use Titanium fasteners or install steel or aluminum fasteners wet with a Zinc based primer. Depending on the chemistry of the metal, any metal will react with other metals or materials.
Old 11-27-2022, 11:14 AM   #5
Damon
Damon's Avatar
The longevity of metal cases largely depends on the corrosion resistance of the product's materials. An oxide film forms on the surface of aluminum sheets immediately after they leave the forming line. Its presence protects the metal against corrosion traces due to high humidity and prolonged contact with water. Steel is much inferior to aluminum in terms of corrosion resistance. Therefore, chromium and nickel are added to such raw materials at the melting stage, which turns the alloy into stainless steel. Nevertheless, I would give preference to steel materials. For example, I recently bought one at https://www.scrooz.com.au/hardware/joist-hangers/.
Damon is offline   Reply With Quote
Old 11-28-2022, 11:16 AM   #6
Mike Jones
Liked 684 Times in 289 Posts
You can put a little aluminum paint/primer in the hole. Outside too, if you don`t mind it. Then wipe it neatly.
Old 11-29-2022, 09:53 AM   #7
SSDiv6
Yes. It has been a standard practice in aviation for decades.
