Old 09-08-2020, 01:57 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Dry Ice.
Anybody ever put a little bit in your fuel cell when chillin the motor? When chilling do I need to richen up the motor. Lt1 combo. 12.9-13.1 is my AFR.
Kdw1403 is offline   Reply With Quote
Old 09-09-2020, 03:27 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Dry Ice.
Yes and it is not advisable.
Todd Bailey is offline   Reply With Quote
Old 09-09-2020, 03:46 PM   #3
Kdw1403
Lol. Thanks. You sound like you are talking from experience.
Old 09-10-2020, 12:25 PM   #4
Todd Bailey
You have a message.
Old 09-10-2020, 12:49 PM   #5
Al Wilson
Liked 109 Times in 38 Posts
I was asked if I had done that when I was borderline on a fuel check once.
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 09-11-2020, 12:37 PM   #6
r429469
Liked 40 Times in 26 Posts
Wondering, can the dry ice be placed in a secure container then placed in the fuel cell, then removed before starting the engine for the race?
r429469 is offline   Reply With Quote
Old 09-11-2020, 01:41 PM   #7
CMcAllister
Liked 929 Times in 263 Posts
Is "artificial cooling" not legal? Is fuel temperature not a part of fuel check?
Just asking.
CMcAllister is online now   Reply With Quote
Old 09-11-2020, 02:38 PM   #8
JeremyDuncan
Liked 355 Times in 80 Posts
Dry Ice has to be vented
JeremyDuncan is offline   Reply With Quote
Old 09-11-2020, 03:07 PM   #9
Painter
Liked 162 Times in 45 Posts
You MUST remove the foam! MUST. The dry ice has nothing to do with water so it won’t dilute the fuel and will be gone by fuel check. They check fuel temp after the run to determine the correct chart to use for the fuel check. If you refrigerate your gas and use a cool can it’s pretty cool anyway.
Painter is offline   Reply With Quote
Old 09-11-2020, 05:33 PM   #10
Capri
Liked 27 Times in 14 Posts
Ever had that feeling in your stomach from too much acid and its bubbling?
Capri is offline   Reply With Quote
