#11 |
Liked 5,076 Times in 1,935 Posts
Don't waste your time and money on bias plys
You're dealing with a new combo that may not be the best for U/SA. Don't leave any ET on the table. There are plenty of used radials out there for sale from the higher class cars , that will work very well for you.
#12 | |
Liked 788 Times in 241 Posts
Jim Caughlin SS 6019 |
#13 | |
Liked 704 Times in 281 Posts
#14 |
Liked 10,650 Times in 2,209 Posts
That was the V/S combo in the truck. If you have the power to use them Goodyear 1909 is a good stick tire.
#15 | |
Liked 226 Times in 74 Posts
#16 | |
#17 |
Liked 1,903 Times in 571 Posts
It s been quite a few years ago since I went from Bias to radial. When I made the switch I made two run with the radials and took them off. They were ill handling. I put bias back on and ran it that way for several more races. I was forced to put the radials back on the car one day due to getting a flat. I put the same air pressure in the radial as in the bias and the next pass was 0.13 faster than with the bias tires and handled perfectly. Both times I tested this the result was the same . Since then I run the radials all of the time and run them about 13 psi.
This is a super stock car and I run the Hoosier 13.5 x 31.5 radial
Mike Pearson 2485 SS |
