#1 | |
Liked 372 Times in 129 Posts
Carl Some years back I had a contract to build Winston West 9.1 comp 390 carbed 358 engines. We were quite sucessful and won several races, every engine we built had roller cam bearings, but also were dry sump. I never saw any weird stuff going on in those engines, they made right at 600 HP. Not going to say there was no harmonics, but we never had problems. We also built some with 55 MM babbit, I never saw any difference on the dyno, I did like getting rid of the oil leaks. Last edited by HP HUNTER; 05-21-2020 at 10:30 PM. |
Liked 70 Times in 22 Posts
Anyone have any experience with roller cam bearings on the street. I have 2 Gen3 hemi aluminum blocks that have been cut for 60mm roller bearings. These are in a cam tunnel so no oil from the top and I don't know if you could put a hole in the bearing cage for oil without hurting the bearing. These are destroked and bored to 305" and Bryant cranks and blocks are cut for LS chevy bearings to get a full thrust bearing for road racing. I was thinking of 1 for a street rod but not sure the bearings would oil enough at low RPM on the street. Any thoughts?
Stewart Way 2424 SS |
#3 | |
Liked 970 Times in 308 Posts
#4 | |
Liked 1,580 Times in 582 Posts
Liked 779 Times in 193 Posts
Isky "Imperial" camshafts.
#6 | |
Liked 996 Times in 275 Posts
Duane Hoven 1342 SS/GT |
Liked 269 Times in 99 Posts
Harmonics are probably always there it is when they magnify become intolerable would think is dependent on operating rpm. Friend had severe believe valve train issues with a Ford combination in a Late Model years ago when changing engine builders the second had him take gear away problem solved.
#8 | |
The closed tunnel blocks started to show up after Mike Ege, the head of the NASCAR engine shops for Robert Yates Racing and years later, for Roger Penske Racing, built the first closed cam tunnel Ford engine block while working for Yates. Mike later incorporated the same feature on the Chevy and Mopar NASCAR engine blocks while working for Penske. |
#9 | |
Liked 18 Times in 10 Posts
The 55MM bearing you used probably had 3 oil holes = huge oil, A few years ago I had 55MM babbit bearings designed with one oil hole and a groove. A lot of my customers have said going from Roller to babbit once the adjust the valves nothing changes in lash going to babbit which is good indicator there is less harmonics having the cam floating film of oil VS iron to iron. |
