Liked 125 Times in 59 Posts
I used to use Amsoil 10-30 Dominator in my bracket engine. I believe it saved me from myself a long time ago. I had a needle stick and when I went to start it you can guess what happened. It spun just a bit and stopped. I was ignorant of what can happen and wanted to race that day so I pulled the plugs, spun the engine over and pumped out the alcohol that had built up in a few cylinders. The engine started and I raced on. Made 85 more passes on that engine before tearing it apart. When the head came off and I looked down you could see #1 piston c0cked in the cylinder. When I got it completely apart I couldn't believe it lived. Here is the rod that came out of it. I used to have a pic of the bearing also but couldn't find it. This is embarrassing but oh well.
The only reason I stopped using it was because it wasn't convenient to get then. I use Driven XP-7 now. ![]() ![]() Sometimes ignorance is bliss. LOL Curtis |
Liked 309 Times in 118 Posts
Here's some good links to Amsoil specs and explaining their multi grade and Dominator oils, he has many more interesting videos about oils.
https://amsoil.lube-direct.com/2011/...nc-oil-amsoil/ ppm chart zink for flat tappet explaining why their multi grade is better. https://www.youtube.com/user/thelubepage/videos more vids. |
