Old 01-25-2020, 10:52 PM   #1
BRINK
Liked 140 Times in 43 Posts
To clear up my last post, Larry and I are the only two racers in S/S running that motor. There are several other racers running the 1974 GTO in Stock Eliminator. But only two in Super/Stock.
BRINK is offline   Reply With Quote
Old 01-25-2020, 10:59 PM   #2
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Here's round 1 of class elims, in SS, at the 2015 US Nats. Bill Rink won his SS/LA class. Robert Cruzen won his GT/AA class. Mike Morgan was RU in his SS/MA class.
Old 01-25-2020, 11:21 PM   #3
oldskool
oldskool's Avatar
"... The only Pontiac Ventura II in 1974 with the ram air 350 at 200 HP was the GTO, not any other variant...."
Wow ! That means that all the info on the Class Racer Info site, about the cars that engine can be used in is absolutely wrong. It shows that engine to be legal in all Ventura models, including 4-doors, & most Lemans models, including 4-door models.
http://www.classracerinfo.com/Engine...px?ENGINE=2088
The NHRA site seems to show the same info as the Class Racer Info site.
http://www.nhra.net/tech_specs/class...s/1974PONT.xls
Maybe it's sorta like it is with the SD455 engine. Some online sources say that engine was only released in Birds. But, some say they know of one or more that came in a GP. So, NHRA allows it in more than just Birds.
I think a member here runs that Class Racer Info site. Maybe I should give him this info & see what he can get from NHRA, on it ? He probably wants all the info on the site to be accurate.
The Wallace engine ID site does list a '74 4-barrel 350, that is not a GTO engine. The block code is WN. Looks like it was 170hp with 4C heads, & 200hp with 46 heads. So, MAYBE, a 200hp version was available in some models other than just the GTO. I DON"T KNOW !
1974 350 170/200 HP WN M 7.6 555 4C/46 1-4 7044269 Block Casting # 488986
http://www.wallaceracing.com/enginesearch4.htm
The 1st hint I had that a non-GTO Vent could run the same engine was from the pics from the '74 US Nats. Al Vanis won, in a flat hood Vent, in O/SA. Rock Running won the O/S class in his '74 GTO. To me, that means the 2 cars were running the same engine, one with auto, one with stick. Don't think a 2-barrel engine would run O, when the GTO also ran O.
http://www.classracerinfo.com/Engine...px?ENGINE=2083
The Class Racer Info site shows that the 170hp 4-barrel 350 can run the same cam as the 200hp engine.
Also shows the same min chamber volume & max CR, for both engines. I'm not saying they were the same from the factory. But, it looks as tho NHRA allows the same specs for both. The Wallace site shows that the non-CA GTO engines used the 066 Pontiac cam. I've read that although the GTO engine was said to have more CR, that they actually used exactly the same cc chambers as the non-GTO 350. Again, I DON'T KNOW !
http://www.classracerinfo.com/Engine...8&MAKE=Pontiac
One thing appears certain. What came from the factory, & what NHRA allows, are sometimes 2 completely different things !
Name:	O-SA Vent .jpg
ID:	53550   Click image for larger version
Name:	O-S GTO .jpg
ID:	53551   Click image for larger version
Name:	O-SA Indy Winner .jpg
Old 01-26-2020, 02:11 AM   #4
oldskool
oldskool's Avatar
At the 2012 Winter Nats, there were 5 Pontiacs in SS.
https://www.dragracecentral.com/DRCS...r2012#indextop
Here's the 1st round.
Old 01-26-2020, 02:33 AM   #5
oldskool
oldskool's Avatar
There were 4 SS Pontiacs at the 2016 Sports Nats.
https://www.dragracecentral.com/DRCS...r2016#indextop
Here's the 1st round of class elims.
Old 01-26-2020, 11:28 PM   #6
oldskool
oldskool's Avatar
Just for entertainment purposes, here's a 9 sec test run of an SD455 powered GT Bird.
Old 01-26-2020, 11:36 PM   #7
oldskool
oldskool's Avatar
How about Don K's East Coast swing video ?
