Old 01-22-2020, 12:53 PM   #1
gfbdiesel
Liked 2 Times in 2 Posts
Default synthetic oils
what do y'all think about synthetic oil in the engine, transmission, and the rear end. does it help to make the car more consistent?
gfbdiesel is offline   Reply With Quote
Old 01-22-2020, 04:42 PM   #2
340Cuda
Liked 756 Times in 328 Posts
Default Re: synthetic oils
I don't know enough to tell you anything about the transmission and engine oils but I strongly feel that going to synthetic lube in my Dana 60 has eliminated the first run of the day being slower, even if the car had been warmed up on jack stands.
This makes me think it would be more consistent for the rest of the day as well.
340Cuda is online now   Reply With Quote
Old 01-22-2020, 07:18 PM   #3
gfbdiesel
What weight gear oil is everyone using?
Old 01-23-2020, 10:42 AM   #4
340Cuda
75-90W for me.
Old 01-23-2020, 01:04 PM   #5
Jeff Stout
Liked 704 Times in 281 Posts
This. I had the same result with first run in the morning and not getting regular oil warmed up enough. Now first run is consistent with other runs.
Old 02-22-2020, 12:25 PM   #6
Charlie Yannetti
Liked 191 Times in 82 Posts
Get with your local Lucas dealer.. I use synthetic motor oil and gear oil, and my trans guy recommends the semi-synthetic in the trans.. and there is usually a Lucas dealer at ALL races...
Charlie Yannetti is offline   Reply With Quote
