Old 11-27-2019, 08:26 PM   #1
CWhitney
CWhitney's Avatar
Liked 12 Times in 6 Posts
Default Re: Stock Eliminator Fairlane
Speedhaven you can email me or call. I'll try to answer your questions.
cwhitney167@gmail.com
CWhitney is offline   Reply With Quote
Old 11-27-2019, 08:47 PM   #2
my69396
Liked 46 Times in 20 Posts
The best way I have found to make sure the tires are in the right place is to put the rear end housing on the springs with the u-bolts and not have the housing welded to the pads with the wheels that you think would fit. Then set the car on the tires at ride height and see where there is any fitment problems. Not being welded you can move the housing around to make the tires fit the best in the wheelwells as most bodies don't sit completely square with rear axle.
my69396 is offline   Reply With Quote
Old 11-28-2019, 01:04 AM   #3
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Between Chris and RJ Sledge I cannot imagine anyone who knows more about what you are trying to do. looking forward to seeing your car done
