#1 | |
Liked 4 Times in 3 Posts
Liked 26 Times in 13 Posts
If your joists run across the ceiling left to right, perhaps you could position a lift like this one so that the top beam is in the space between two joists?
https://www.bendpak.com/car-lifts/tw...lifts/gp-7lcs/ Here is a good article on home shop lifts. https://grassrootsmotorsports.com/ar...stalling-lift/
Bill Harris ex 2172 STK ex 2272 S/S |
Larry,
You may want to look at MaxJax Portable Two post lifting system. The web site is maxjaxusa.com Hope this will help. |
Liked 118 Times in 41 Posts
I had a 9 foot ceiling in my garage and had it raised 2 feet. Works really well.
U/SA 79 Mustang |
Liked 358 Times in 83 Posts
I have a friend that just bought a very good quality movable scissors lift and used it to R&R the transaxle on his son's Monte Carlo. Said it worked really well, lifted the car high enough (he and his son are around 6-feet), and was a Godsend, given the complexity of the job. I think every lift configuration is a compromise, in one way or another. I have a two-post, above ground, and it's certainly nice to have, but it has definite drawbacks.
Liked 887 Times in 239 Posts
Larry ,I've got one of these lifts at home for the race car , but it works great on almost anything . and it is portable.
Had it since 2012 ,no problems . https://www.gregsmithequipment.com/A...-Mid-Rise-Lift
Liked 77 Times in 15 Posts
I bought a Max Jack lift from Rineharts Performance at a great price (and they can have it shipped to you). They told me it would be the best tool I ever bought and I would wish I bought it sooner. They were right.
Lots of YouTube videos on install and options for setup. I had no DIY install issues and it works great. I did have extra lines made to run my hydraulic lines across the ceiling, to remote locate the pump. No tripping over anything, which is the only negative with the setup as it comes, but that was personal preference. I have a regular height, basic 2 car garage, and the Maxjax has two heights with safety pins. When in the high position, you can sit on a stool and roll around and work under the car easily. Last edited by Matt Welker; 11-27-2019 at 10:33 AM. Reason: More info |
Liked 188 Times in 62 Posts
I just bought a Max jack for my garage from all places home depot. Got a discount and 18 month no interest payment. I'm retired auto tech with 50 years in the field .Will lift 6000 lbs. to approx. 4 ft. works very well and doesn't restrict working in center of car like some do. I also have a 8 ft. ceiling.
Liked 319 Times in 68 Posts
That's what I did worked out great can raise the car high enough to stand under. Cut a 4x8 section and raised two rafters gen 3&4 roof fits perfect.
Lee Valentine 1661 STK |
