Old 11-23-2019, 11:58 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Mid-Rise scissor lift feedback from owners/users
Because I sold my automotive shop and have set up shop in my home garage my lift options have changed.
The garage has an 8-foot ceiling so I must accommodate that limitation while lifting the car as high as possible.
The car is my personal 3rd gen Camaro, "Lamplighter" project and this is the only thing the lift will be used for. While under construction and then when completed the Lamplighter will weigh less than 3,000 pounds.
My intention is being able to lift the Camaro high enough to work under it while seated on a roll-around stool.
I want to hear about your personal experience plus brand of lift and who you bought it from.
Larry Woodfin 471W
Old 11-23-2019, 03:55 PM   #2
james schaechter
Default Re: Mid-Rise scissor lift feedback from owners/users
I would look into “quick jacks” Costco has them and you can also use them at the track.
https://www.costco.com/quickjack-5%2...100460313.html
Casey Miles bought a set and loves them. I saw a guy at the drag strip use them as well. I am seriously considering a set for our Cavalier
James Schaechter 3163 STK
Old 11-23-2019, 04:51 PM   #3
Dragsinger
James, it only raises 21" - not enough for a man with FOS [Fat, Old, Stiff]
Larry Woodfin 471W
Old 11-23-2019, 05:07 PM   #4
G Anderson
Liked 4 Times in 3 Posts
While I have yet to buy a hoist I had the trusses cut ,lifted and raised to 10'2" in 1 bay of my 2 car garage in anticipation of a hoist purchase
G Anderson is offline   Reply With Quote
Old 11-23-2019, 07:39 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
If your joists run across the ceiling left to right, perhaps you could position a lift like this one so that the top beam is in the space between two joists?
https://www.bendpak.com/car-lifts/tw...lifts/gp-7lcs/
Here is a good article on home shop lifts.
https://grassrootsmotorsports.com/ar...stalling-lift/
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-25-2019, 06:55 AM   #6
Charles Hawthorne
Larry,
You may want to look at MaxJax Portable Two post lifting system.
The web site is maxjaxusa.com
Hope this will help.
Charles Hawthorne is offline   Reply With Quote
Old 11-25-2019, 08:10 AM   #7
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
I had a 9 foot ceiling in my garage and had it raised 2 feet. Works really well.
U/SA
79 Mustang
Old 11-25-2019, 08:11 AM   #8
nhramnl
Liked 358 Times in 83 Posts
I have a friend that just bought a very good quality movable scissors lift and used it to R&R the transaxle on his son's Monte Carlo. Said it worked really well, lifted the car high enough (he and his son are around 6-feet), and was a Godsend, given the complexity of the job. I think every lift configuration is a compromise, in one way or another. I have a two-post, above ground, and it's certainly nice to have, but it has definite drawbacks.
Old 11-25-2019, 01:56 PM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
Larry ,I've got one of these lifts at home for the race car , but it works great on almost anything . and it is portable.
Had it since 2012 ,no problems .
https://www.gregsmithequipment.com/A...-Mid-Rise-Lift
Old 11-29-2019, 08:29 AM   #10
Lee Valentine
Liked 319 Times in 68 Posts
That's what I did worked out great can raise the car high enough to stand under. Cut a 4x8 section and raised two rafters gen 3&4 roof fits perfect.
Lee Valentine 1661 STK
