Old 11-20-2019, 09:15 AM   #24
Tom Broome
Liked 88 Times in 43 Posts
Default Re: Mopar 383 Connecting Rods
Originally Posted by HP HUNTER View Post
You have two rods you're honing..........there's .0025 to hone to size on both rods, one rod has .0005 taper the other has .0007 taper. How do you set these two rods up on the already trued mandrel?
Please pardon, I adjusted your post for clarity.
Okay, I'll play. We're just having fun here........Right?
Let's assume you cut the mating surfaces and are resizing the rods in your example.
Let's again assume you cut the mating surfaces enough that you started from a dimension smaller than you currently have (-.0025). And you honed the rods to this dimension.
Once again, let's assume that you find the taper begins at the surfaces you were holding together, and progresses outward on both rods.
And yet again, let's assume that you have been flipping this pair of rods over every half thousandths or so. You do flip your rods over don't you?
Still yet again, let's assume that you have not been over-stroking the rods beyond the honing stones too much.
One more assumption, let's assume you are honing those rods with the beams riding on separate torque bars, not the same bar.
There are still a few more things to assume, you did deburr the bolt holes at the parting line, you did make sure that the cheeks of each re-assembled rod was...were...are... flat. Because, after all that work you don't want the pair of rods you are trying to hold together to be a couple of "rocking horses".
Answer: When that happens to me, I push the "OFF" button and walk away for a while. Because it's a clear case of operator error.
What did Dirty Harry say?
Tom Broome is offline   Reply With Quote
