Liked 372 Times in 129 Posts
Liked 184 Times in 113 Posts
They are already in the engine.
Budd Rowe fitted the Pink Rods with Forged pistons, about 8 years ago. Engine has been in storage and Rockville Ring and Bearing just went through the block with fresh bearings. If i kept them what RPM range would be safe? One racer posted he used them in a SS engine at much higher rpm than 7000 rpm. Only have so much tine and money.. D |
#3 | |
Liked 1,001 Times in 276 Posts
If you are second guessing yourself and want to upgrade, get the Eagles. I run them in my Boss 302, making 540hp shifting at 8700 and going thru at 8900 in good air with no problems. Just make sure you get them with the arp2000 bolts, and check the big ends and small ends. For 500.00 you can't go wrong.
Duane Hoven 1342 SS/GT |
#4 | |
Mine only goes ~8400 in the lights. Best I have found are Manley. Light, and all sizes dead nuts. This was three years ago. Eagle may be better now.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 11-13-2019 at 08:13 PM. |
Sucks moving from Pure Stock to Stock..
Both engines SBC and LT1 were originally designed for under 7000 rpm. With stock stuff... Prepped Pinks and LT1 rods seem to be ok to 7200 rpm. Stockers are mini SuperStock Engines hitting ridiculous RPM. Above that a lot more costs and still questionable reliability. Then adding roll bars, reinforced rear ends, replacing harnesses every two years, European priced fuel for racing. Where is the fun? |
Liked 133 Times in 76 Posts
Have they been bushed for floating pins or are they still press fit which is what they were new.
Are these Hbeam rods or I beams that are turned 8000?
