Old 10-07-2019, 06:22 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Re: Funny TPS readings ...
If it is GM I am pretty sure you can pick that up at the parts house. What system are you running? Pull it off the throttle body and see if the plastic is all chewed up. If it is loose and vibrating going downtrack you will get erratic readings and that will be detrimental to the performance, especially in Alpha N mode.
'65 Mustang SS/L & L/SA
Old 10-07-2019, 06:27 PM   #2
Kdw1403
Liked 68 Times in 22 Posts
Fast xfi2.0. I’ll take it off and check. Thanks
Kdw1403 is offline   Reply With Quote
Old 10-08-2019, 11:51 AM   #3
Liked 10,837 Times in 2,252 Posts
Fast web site lists those parts
Old 10-08-2019, 01:18 PM   #4
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
I would recommend using an OEM TPS sensor. What is the application? Have you learned the tps sensor?
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 10-08-2019, 09:28 PM   #5
Kdw1403
I just bought a TPS. Do I just install it or as you say do I have to calibrate it or learn it? Your car was flying in St. Louis.
Old 10-10-2019, 06:44 PM   #6
countrypuppy4865
Anytime you change a sensor you definitely want to calibrate it.
4865 E/SA '04 GTO
Old 10-10-2019, 07:49 PM   #7
Ed Wright
Ed Wright's Avatar
Easiest way I know, is to slot the little screw holes in the TPS, so it can be rotated like an earlier year model adjustable TPS.
I have not had one fail to show 100% Throttle Angle, if the Throttle Body is opening all the way, against the stop. Don’t buy your sensors at Autozone. Use genuine AC Delco, or NAPA.
Ed Wright 4156 SS/JA
