Old 10-04-2019, 04:11 PM   #1
Pat6868
Liked 93 Times in 29 Posts
Default Re: Engine diapers on S/SS?
Originally Posted by rboyle View Post
I never tried to fit one. Anyone have any experience trying to fit one and if so which one actually fits a Stock type chassis?
I don't want it mandatory on my stocker, period.
Pat6868 is offline   Reply With Quote
Old 10-04-2019, 05:57 PM   #2
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
After seeing multiple incidents of oil downs over the years, I made the decision to put a diaper on both my bracket car AND my stocker. For me it’s about my own safety. I have personally had an occasion where I wished I had one( popped an oil line and got oil under the tires , saved the car but scary all the same).
I use the generic fit ones from summit/jegs. They don’t interfere with anything and only take minutes to install. I would have to pull my engine for a rod/ piston pull any way.
My friends use the DRE brand on some of their cars. Excellent product.
Safer is not sorry in my opinion. No downside to this accessory for me.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 10-04-2019, 06:05 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Your tune might change and if you couldn’t fit one. I’d install one of DRE’s without question but unfortunately all chassis/pans/headers are not the same. I’ve even had diapers enable me to make a final when I had a water pump gasket start leaking.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-04-2019, 09:43 PM   #4
00SSCamaroZ
Liked 11 Times in 4 Posts
Well I don't think I've ever seen a stocker oil the track. However at the Dutch on Friday afternoon a blue 69 camaro did a moonshot wheelstand and upon landing pitched out what appeared to be the trans blanket. That was something new in my world.
Mike Z
00SSCamaroZ is offline   Reply With Quote
Old 10-04-2019, 10:33 PM   #5
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
We had a Jr. Dragster oil the track this year. Last weekend it was a Stick car that split the trans case. Numerous rear end explosions, auto trans blowups, oil line leaks and rad hose failures. I'd think engine failures are becoming a lot less with improved and accepted parts.
I'm all for safety but how many Diapers should be on a race car anyway. If you want to run one then fine, but I don't, probably can't fit one and don't think making them mandatory is a good move.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 10-05-2019, 07:15 PM   #6
Doug Walker
Doug Walker's Avatar
Liked 3,291 Times in 300 Posts
Mike Z
Are you referring to this ?? Blue Camaro was in the left lane. Debris was in the right lane, but may have originated from either car.
Does not look like 1969 Camaro to me, but maybe more than one car pitched its safety gear off mid track.
First time I'd ever seen this happen.
ID:	52460   Click image for larger version
Old 10-06-2019, 08:17 AM   #7
00SSCamaroZ
That looks like it. Thought it was a 69. Obviously not. Guess I am not a good eye witness.
Mike Z
Old 10-06-2019, 09:38 AM   #8
rboyle
rboyle's Avatar
Liked 598 Times in 164 Posts
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
