Old 09-19-2019, 03:36 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Chiller recommendation.
Do they work? Which type is best? How much do they cost? Who should I call? What all is needed? How cold do I go? Anything I need to change on tune up? EFI car. Fast system. How much does it pick you up ET wise on a 85 degree day . Thanks
Kdw1403 is offline   Reply With Quote
Old 09-23-2019, 10:48 AM   #2
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Default Re: Chiller recommendation.
A professional type 110V chiller can cost upwards of 2 grand. Most guys in Stock/SS either dumb the water at the head of the lanes and refill with cold water, Or use a cooler with ice water in it and circulate the water through the cooler.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 09-23-2019, 11:36 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
Steve offered a good over view. Are you looking for a cooler to use every round? One that you can use for a heads up run, a qualifier, etc? For E.T. improvement, I've seen a minimum of .004 to as much as .010...depends on the car.
Brainerd Stock winner Chris Knutson uses this one:
"That'll never work....."
Old 09-23-2019, 11:40 AM   #4
Jim Kaekel
Liked 535 Times in 110 Posts
Here's an article I wrote a few years back about engine chillers. All it takes is a good-sized ice chest, a swimming pool pump, rubber garden hose, Jiffy-Tite quick connect fittings and a C&R one-way coolant valve.
http://www.laneautomotive.com/lanemo...ownEffect.html
Jim Kaekel 3836 STK
Old 09-23-2019, 05:53 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I built a chiller a few years ago that refrigerated the water like the 2K ones, it worked great, all the same parts and pieces as the cooler full of ice deal. The only problem, my 7K generator could not handle the LQ A/C, chiller, pumps and misc. The cooler, sump pump, and a lot of ice is the way to go. We used to take plastic coffee containers and freeze ice and store up for a race with the stocker motor.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-23-2019, 06:34 PM   #6
FED 387
Liked 334 Times in 181 Posts
check your PM--FED 387
Old 09-24-2019, 10:12 PM   #7
Kdw1403
Yea I like the one in the pic. I want it just for heads up runs.
Old 09-25-2019, 09:10 AM   #8
Rick Schilling
Liked 14 Times in 10 Posts
You probably should still get some input from someone on the tune up as well. You don't want to run the car stone cold, but I know of at least one instance of "overcooling" that caused a fuel injected car to slow in a very critical race.
Rick Schilling is offline   Reply With Quote
Old 09-25-2019, 10:31 AM   #9
Keith 944
Keith 944's Avatar
Was wandering the same. Has anyone had this backfire like a bog or slow down from being too cold?
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Keith 944 is online now   Reply With Quote
Old 09-25-2019, 01:03 PM   #10
Sean Marconette
Depending on what EFI system and what it is looking at to make tuning decisions, colder can definitely be a big problem. Any modifier that is adding fuel based on water or air temp could make it too rich or lean. Open vs closed loop and how much you allow it to add/remove fuel. As long as you are you willing to adjust the tuneup and these parameters it could make a difference.
Sean
Sean Marconette
84 Mustang
5060 SS/N
