Liked 13 Times in 11 Posts
If I read correctly , an A car in S.S. carries 6lbs / hp. So the factory "rated" the 427 ( was that a tunnel port?) at 425 hp? So Paquet's car only carries 2550 / 2600 lbs?
http://www.classracerinfo.com/NHRA_Classes.aspx or: http://classracer.com/classes.html so is it LBS / hp or LBS / cid? Last edited by joespanova; 09-24-2019 at 11:37 AM. |
Liked 64 Times in 23 Posts
Hi Riser, not a Tunnel Port
Jody Aberts Troublemaker2 1966 Fairlane 427 |
![]() OK , and.......... I wanted the weight confirmation....? Am I close ? Last edited by joespanova; 09-24-2019 at 12:17 PM. |
Liked 566 Times in 135 Posts
Super Stock factor for the T-Bolt is 466 (or 482 with replacement heads).
466x6.00 + 170 = 2966# or 3062# with replacement heads. |
Liked 355 Times in 80 Posts
170 lbs is added for drivers weight
Liked 249 Times in 48 Posts
They are weighed together so the weight can come out of the car as is necessary in my case.
Pete |
#9 | |
I don't know why he indicated the 170? I'm confused...........again....lol. |
The car weight is figured as rated hp X lbs/hp for class plus 170 for the driver. All drivers are figured at 170 and you make up the difference from there.
Pete |
